Old 08-02-2005, 05:06 PM   #1
bluec10
bluec10's Avatar
Question Clutch Won't Engage
Cleaning out the garage and had to move my '69 onto the driveway. No problem, I thought. The truck started right up (the last time I started it was three months ago) but it lurched ahead as I turned it over. I had the clutch pedal all the way to the floor. I shifted it into neutral and it started fine, but when I put the clutch in to put it in gear, I got nothing but grinding.
The last time I started the truck it worked fine. What could be the problem?
Present:
2015 Tacoma. Yeah, not a GM, but I love it.
1969 GMC 32,000 - fix, drive, relax, fix...
2019 BMW R1250 GSA - Yahoooooooo
1979 Honda GL 1000 - retro touring at its best.
Past:
'05 Sierra 4x4 - Had 270,000 KM and running well when it was written-off by a stop sign runner.
'94 F-150 from the "F word" company. I'll admit it...good truck. Sold what was left of it for $800 to a guy who came to pick it up at 11:00 PM with cash in hand. Hmm.
'79 Sierra Grande (Black) organ donor - perfect rebuildable 4-bolt 350 and a good TH350.
'76 Sierra Grande (Orange) - hate isn't too strong a word. Kid who bought it turned it into a hot rod.
'68 C-10 R.I.P. - Dad's old truck...too far gone to resurrect.
'59 C-50 - with hoist. Truck is gone, wife isn't. Nuff said.
bluec10 is offline   Reply With Quote
Old 08-02-2005, 05:33 PM   #2
.030over
Junior Member
.030over's Avatar
Disc is stuck to pressure plate/ flywheel
That is kind of common when stuff sits. My Big block Camaro used to do it. You may try running it a while in neutral then turn it off and put it in high gear and crank it with the clutch depressed. The lack of gear reduction should keep the truck from moving and hopefully the starter torque will break it loose. Mine always did.
Scott
'67 SWB big block project
'85 C60 school bus motorhome conversion
.030over is offline   Reply With Quote
Old 08-02-2005, 06:55 PM   #3
bluec10
bluec10's Avatar
Thanks for the suggestion. I'll let you know how it goes.
Present:
Past:
Old 08-02-2005, 11:24 PM   #4
68C15
blood type; Retumbo
68C15's Avatar
or put it in low, push clutch,start engine, let out clutch to start moving slowly, push clutch in again & floor it a couple of times. this way there will be less load on the starter.
it sounds like you have rust buildup on the input shaft of trans where the disc would normally float.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 08-03-2005, 10:17 PM   #5
teamroper!
teamroper!'s Avatar
I'm glad that I read this. The same thing happened to me this afternoon except that mine has only been sitting for two weeks!
teamroper! is offline   Reply With Quote
Old 08-04-2005, 12:52 AM   #6
bluec10
bluec10's Avatar
I idled the truck for quite a while on a pretty hot day to get everything nice and loose. I tried the starter and third gear thing a few times, but it didn't work. I finally went 1-2-3-Up and popped it into reverse. I heard a thunk and the clutch let go.
It's all good.
Present:
Past:
