18436572
Aftermarket Trans crossmember
I'm installing a TPI motor and 700R4 in my 70' C10 2wd Short. The stock crossmember just won't seem to go back in. I will be bagging my truck in the future so can you guys recommend an aftermarket crossmember to work?
Thanks. Any other tips for this install would be helpful. |
18436572
I'm looking at the ECE crossmember but i wanted to check here first.
MY EX DRIVES A BROOM
all i had to do was slide the motor foward about 1/4 inch...the holes in the motor mounts were elongated so this was not a problem.....and put my stock x-member in the th400 location...then everything bolted right up.
They say nobody's perfect. I'm a nobody, so I must be perfect. Building Nemo -1968 C10 Long Bed FRED -1947 KB-2 International |
the motor mounts i'm taliking about are the ones that bolt from the frame to the x-member the 2 holes in the top on the frame are elongated.
I used the stock one with my 700R in the 8 and 6 cyl position. You may have to drill new holes in the frame but it will work even with a bagged truck. The ECE or CPP and Brothers crossmembers are all the same. I have seen it in a local shop here looked good but why spen the money if yours will work ? Be sure to install the stocker with the slope back not towards the front.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
