Old 08-03-2005, 12:18 AM   #1
skokie
skokie's Avatar
Grounding
If you dont have any accessories holes in the head where do you run the ground to on the negative side of the battery post?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 08-03-2005, 12:30 AM   #2
68LSS1
68LSS1's Avatar
Doesn't really matter. Alternator bracket works as does a exhaust manifold bolt. As long as it's clean and protected.
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 08-03-2005, 12:35 AM   #3
skokie
skokie's Avatar
How about a wire from the negative post to the frame or rad support?
68 build thread
Old 08-03-2005, 12:42 AM   #4
71swb4x4
71swb4x4's Avatar
I ran mine to the water pump. I have also seen them go to the exhaust manifold.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 08-03-2005, 12:46 AM   #5
68LSS1
68LSS1's Avatar
As long as you ensure that the engine, cab and frame are all grounded together the battery can be grounded to any of them. Personally, I like to ground the battery to engine (unless the battery is in the back), the engine to the cab and the cab to the frame. It can be done many ways just remember that it will require a little preventive maintenance to ensure you don't have any starting/charging/erratic accessory operation.
Edit for: I know that for example, the cab is grounded to the frame via the cab mounts but I suggest using dedicated ground straps. Use another from the engine to cab, etc. If you do this you will never have a ground issue.
'68 Short Step
Old 08-03-2005, 01:44 AM   #6
69 Short Fleet
I have mine grounded to the frame rail, used my dremmel and cleaned a spot really well (shiney). But what the other guys said is good also. I wouldn't use the rad support though. Dog
69 Short Fleet is offline   Reply With Quote
Old 08-03-2005, 01:47 AM   #7
skokie
skokie's Avatar
Let me ask this one to. What was the stock location for a 68 with a 327? 69 short fleet I believe I meant frame rail but was thinking of rad suppourt at the time
68 build thread
Old 08-03-2005, 03:35 AM   #8
krue
Designated A-hole!
krue's Avatar
On my 70 w/350, mine is grounded on an intake bolt, passenger front corner if I recall correctly
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 08-03-2005, 06:38 AM   #9
69 Short Fleet
I'm not sure if GM kept the neg. battery cable locations consistant for different years or not, ie. all 67's went on the head and all 68's went ont the manifold bolt ect. (just as an example). I'm pretty sure that all the braided ground straps had not much consistancy for the box, cab, firewall ect. as they were placed on different sides of the truck and different locations ect. For example you could have 2 68's built on the same day at the same factory on the same shift and it depended on the GM worker as the workers were given "general" grounding locations to install the braided ground straps. I think Longhorn man was talking about this quite a while back (if I remember right). Doug
Old 08-03-2005, 07:17 AM   #10
neonlarry
neonlarry's Avatar
The reason you want the main ground on the engine is because the biggest current draw is the starter. If your main ground is the frame and all you have is a couple of wimpy briads to the engine all your starter current will have to flow thru them, not ideal.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 08-03-2005, 07:21 AM   #11
Jetmech727
IMO water pump looks best on that style setup
"When cows laugh, does milk come out of their nose?"
Jetmech727 is offline   Reply With Quote
Old 08-03-2005, 07:48 AM   #12
355
355's Avatar
The bolt on the block directly in front of the fuel pump I think is the best. It has good size not subjected to high heat, that can cause resistance. It is the bolt that you use to hold the cam rider in when changing your fuel pump. Just a thought, the number one reason that a AC clutch will burn up is a bad ground. The Rice burners loop the heads, block, Alt, frame, etc all together for better performance from all of the electronic sensors.
1969 C10 Long Step,355,700r4w/lockup, HEI,Weiand,750 Performer,1.6 rockers,Camel Humps,Comp 262Extreme,Hedman,2 1/2"pipes, tele/tilt,SunRoof,ps,Disc pb,ac,Cragar,eaton,Corvette style roll pan, Bowtie louvered tail gate,lowered 2/2.
355 is offline   Reply With Quote
Old 08-03-2005, 09:29 AM   #13
KOOLmike
KOOLmike's Avatar
Remember, electricity always takes the path of the least resistance. Adding copper ground straps will be far better than just relying on the bolt-to connections between components.
1972 Chevy SWB 4x4
KOOLmike is offline   Reply With Quote
