Old 08-03-2005, 12:26 AM   #1
crazy4chevs
crazy4chevs's Avatar
67-72 C-10 axle widths again PLEASE help!!!!
I know it's been asked before but I couldn't find it.
67-72 C-10 axle widths - again PLEASE help!!!!
I need the 2wd long axle and short axle lengths. Thanks in advance, Lance
70 chev c10 swb fleet
72 grill, sb 400, 2/4 drop.
68 chev c10 swb fleet
Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C
Classic GM Truck Club of Washington
crazy4chevs is offline   Reply With Quote
Old 08-03-2005, 07:45 PM   #2
crazy4chevs
Nobody?????
Ive tried the -Google search- the FAQ- and i still cant find it.
I have a 70 c-10 and think that i have the longer axles but am not sure.
If so they should swap with 71-72. but I cant find the measurements for 67-70 and 71-72
I'm trying to swap from 6 lug to 5 lug and a friend has some newer axles for free.
please help
Old 08-03-2005, 08:07 PM   #3
uncle
Swap
If you have a 70 rearend, you can swap. You can measure the housing from backing plate to backing plate. It should be right at 57". If that's the case you can swap axles. You can also check the code on the housing. Most 70 model housings had a 3 digit code like the 71/72 trucks. I just found the measurement for the narrow axle. 30 11/16 and I think the longer axle is aprox. 3/4" longer.
uncle is offline   Reply With Quote
Old 08-03-2005, 11:59 PM   #4
crazy4chevs
Thanks, uncle.
Ok, I got the narrow axle lengths. 30-11/16
Anyone know the 71-72 lengths for sure??????
Would also like to know what the longer ones are.
Thanks in advance!!!!!!
Old 08-05-2005, 07:41 PM   #5
crazy4chevs
ttt
Old 08-05-2005, 08:17 PM   #6
Bamm
Cowboy Fan for Life!!!!!!
Bamm's Avatar
I'm not sure of the measurments exactly, but I do know from personal experience that only SOME of the '70 year model rear ends will swap into a 71-2. I bought a '70 rear that I know was original to the truck and the axles were a different length than my 71-2 rear. I guess it just depends on the build dates on the '70 rears? I know 70 rears come both ways.
1967 ShortBed Fleetside
3/4 Drop 350/700R4
Tilt wheel
18 x 8 Torque Thrust II's
Future mods: All new gauges & wood bed
My Zip is 23002
I ship UPS, USPS
Bamm is offline   Reply With Quote
