Old 08-03-2005, 03:01 AM   #1
Jeremy_5
Truck addict
Jeremy_5's Avatar
frame difference?
Are there any differences between a 67-72 frame and a 73-87 frame?
1956 Chevy Napco
1972 Cheyenne Super
1970 K20
Jeremy_5 is offline   Reply With Quote
Old 08-03-2005, 03:32 AM   #2
krue
Designated A-hole!
krue's Avatar
Yeah, the later frame humps up under the cab more. To put a 67-72 cab on a later frame you either have to do a body lift (which is ok for a 4wd but silly for a 2wd) or channel the floor of the cab.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 08-03-2005, 04:23 AM   #3
Jeremy_5
Truck addict
Jeremy_5's Avatar
thanks Krue. So all the cab mounts are in the same place on both frames?
This might be a little off topic but does anyone know if a bigger cab like a 2-ton cab, will fit on a 67-72 or 73-87 frame? I am not sure of the dimensions of the 2-ton cab. I don't know if it is wider or has different locations for the cab mounts. Any help would be appreciated.
1956 Chevy Napco
1972 Cheyenne Super
1970 K20
Old 08-03-2005, 05:35 AM   #4
krue
Designated A-hole!
krue's Avatar
Don't quote me on the cab mounts. Mudder67 has a 73+ frame under his 4x4, maybe he can help you with the particulars.In 67-72 I'm pretty sure the bigger trucks have the same cab as the 1/2 tons, with a few mods (to make room for the bigger wheel wells, etc).
www.daveramsey.com
Old 08-03-2005, 11:40 AM   #5
Mudder
Mudder's Avatar
If you'll look the mounts on the newer trucks go to the inside of the frame. Older trucks to the outside. In the same general area. They are also all different lengths (wheelbase).
Mudder is offline   Reply With Quote
