Wiseass secured himself a BAN
How do you remove hail dents?
My truck has them on the roof of the cab, hood, and on top of each fender. Anyone have any suggestions on removal?
I tried this on the body and paint forum with hardly any results. Ben |
I have heard if you heat them up with a hair dryer then rub and Ice cube on the spot they will pop out.
Just sitting here contemplating contemplation. |
I tried the dry ice technique on a hot day/heat gun with no success. I'm wondering if the metal on our trucks is not too heavy for that. I've talked to some paintless dent removal guys around and they all say the paint is too brittle on an older vehicle for that. I'm temped to find a flat piece of heavy flat iron, place it on top of my hood over a hail dent and whacking the dents from below with a plasitic hammer I have.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles. TREASURER, Drum Brake Club. |
Now the others dig........
![]() Join Date: May 2002
My brother has some dents on his 87 honda civic....I'm gonna try the ice cube trick when I have time!!!
68 Chevy C10 Stepside Black Primer 78 GMC Longbed White 09 Chevy Silverado Shortbed Granite Blue LOOKING FOR A 67 4 DOOR IMPALA!!! ![]() MEMBER OF THE DRUM BRAKE CLUB Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX Certified Music Educator I hope Mom is up there watching and being my Guardian Angel "I've got a fever.....and the only prescription.....IS MORE COW BELL" -The Legendary: Bruce Dickenson "F#$@ 'em up!!!!!!" -The Legendary: Rogelio Escobar ![]() TRUCKY LINKS http://67-72chevytrucks.com/vboard/s...d.php?t=457750 http://67-72chevytrucks.com/vboard/s...d.php?t=461184 http://67-72chevytrucks.com/vboard/s...d.php?t=472848 http://67-72chevytrucks.com/vboard/s...d.php?t=417541 http://67-72chevytrucks.com/vboard/s...d.php?t=477788 |
Look in the yellow pages for a place called dent busters, or a simular name. We have them around here and call them all the time. They have these things that look like spoons with really long handles. They reach inside pannels and massage out small dents. They have saved many cars from the paint shop. I've seen super nice cars with hail dents all over. They can take dents out not even my dad, who's been painting cars for 40 years, can tell they had been in there, even with dark color cars.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
Recovering Truck Driver
the ice cube trick should work on the civic.......but these trucks are made of better steel...it's alot stouter than anything made today. It looks like you are stuck hammering and dollying the dents out....musta been one hail of a hail storm to ding one of these.....mines lived outside all it's life and i've never seen a dent anywhere that was caused by hail.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
We had a hail storm go through last year and my wife's 95 Honda Civic was sitting next to my 71. Not a dent on my 71 and she had over $1400 damage to her car. Just goes to show what are trucks are made of.
The hail that hit my truck was the size of a golf ball. It also cracked the windshield in 4 places.
I have talked to a guy that has worked in the paintless dent repair business. He said that it would cost more to fix the dents in my truck than it would a newer vehicle with the equal amount of dents. Any more ideas or suggestions? Ben |
The hail that got my truck was golf-ball sized. My Explorer and Winstar were both pounded up much more.
Ol Buck, What's "dollying"??? Would the heavy steel on top of a dent and the rubber mallet from behind trick pop them out? I'm thinking of just the flat areas of the hood. Obviously doing this on the curved areas wouldn't work.
About the only possibilities left is start ordering alot of goodmark body parts. The only cheap thing you could do would be to just keep driving it like it is. If your truck is hurt as bad as I think it is, your gonna be able to buy another truck for what it'll cost to fix yours. No way around it. If you find a cheaper way to fix it, go into business cuz you'll be a millionaire!
I don't know if you have insurance, but good luck with them if you do. These trucks have a book value of about 300 bucks. I don't know if your truck was fixed up or not. You'll probably have to argue with them forever to get more than a few hundred bucks out of them.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks Last edited by Low69CST; 06-26-2002 at 01:12 PM. |
![]() Join Date: Jan 2001
If your going to repaint anyway which it sounds like it works real well to heat the dent up with a torch around the inside edge of the dent and then cool it off with a wet rag. IT works well especially on roof dents. Generally pops it back to original shape.
HF
'66 CST BBW swb fleet 327 fac ac '67 CST 4x4 swb 327 stepside project '72 Cheyenne K20 50k original '72 Cheyenne Super K20 project '73 Sierra swb 4x4 frame off in paint stage '74 Cheyenne Super swb w/16k actual '71 & 72 Cheyenne K10 4x4 swb's '70 426 HEMICUDA conv SHAKER 4 sp Dana 60 '60 Impala conv 327 PG fac ac loaded 3rd owner '72 GMC K2500 4x4 '59 Apache CST BBW fleetside swb 283 '73 ElCamino SS LS1 T56 true SS bucket tach '76 ElCamino SS 52k survivor '87 Grand National 41k True 2nd to last built in 1987. '86 K30 454 SRW fleetside CA since new '88 Trans Am GTA 39k bought new 2018 DEMON plum crazy @ 840HP! "Need for speed" |
In my opinion...
I'd be scared of the torch idea. You can easily warp a pannel. Warp in a hood or roof would would nearly impossible to fix. What I would do is take a hammer and just knock down all the high spots in the pannel around the dent. Then drill holes and use a dent puller on the really deep dents, then coat the whole pannel in filler. Not the most desirable way to do it, but will work fine, Plus theres not many options when it comes to fixing the roof of the cab. Unless you've found another cab you can put on your truck.
#13 |
With 30 years in body work experienece I will tell you you can do this with a torch tip and a wet rag especially with the guage of metal these trucks have. For a novice I would experiment with an old hail damaged hood or something and you'll be amazed what a little heat and a wet rag will do. At the most when you are finished, a good coat of catylized primer surfacer will be all you need to block out for paint.
And if I were going to pull dents the best investment is a stud gun that welds nails to the metal and uses a puller to pull the dent. No holes to weld up. Why not try before replacing with new panels. Otherwise leave it to a professional. |
#14 |
I would even start drillin. Id buy one of those stud welding guns. The ones that weld a nail to metal, then you can use a dent puller on it, no holes to fill, and probably less finishing before paint.
70 shortbed stepside "Schleprock" 350 w/TH400 rallys and BFGs -We can rebuild it, we have the technology-lower,shinier,faster |
#15 |
Easy...move to California!
#16 |
Haha, good call Six Pack!
#17 |
its all about the +6 inches
That's the beuty of a beater, my GMC has hail damage all over it from a stom with golf ball hail. The bummer was it happened 3 tays before moving out of Texas. I coulda already been gone.
![]() The REAL bummer is, it dented my good cab which was under a tree. ![]() Planning on doing the torch thing...done it before. |
#18 |
Please DO NOT DRILL HOLES
I cringe everytime I see it done. Why turn a good panel, except maybe a dent, into swiss cheese? Like mentioned, a torch and wet rag can do wonders. I learned how to shrink metal from one of the best, and watched him one day, take a toyota tailgate, and shrink out every letter, in less than an hr...
Jeff Scott '70 GMC Stepside, Short box '63 Nova '92 GMC typhoon '95 Tahoe |
#19 |
![]() Join Date: Jul 2000
There is a small dent and ding puller called (PDQ paintless dent puller) available from ABC products, Anaheim, Ca. but it is pricey,
uses hot glue and a pulling jig. www.abcpropromo.com
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar. 96 Impala SS 97 Monte Carlo |
#20 |
If you do end up re painting definatly go with the stud gun. Buy,beg or borrow a stud gun from someone. Then all you do is: remove paint from dent, use stud gun to tackweld a stud on, then attach small slidehammer to stud, give a tap or 2, then use a pair of pliers to remove the stud, light sand, bondo, prime,paint.
No need to drill holes or risk a warped panel. Sorry to hear your truck is so banged up ![]() CoryM
1970 heavy duty C-10 fleetside sport truck. Vancouver B.C. Canada http://www.geocities.com/chevroletc1070 "Take up our quarrel with the foe: To you from failing hands we throw The torch; be yours to hold it high." Lieutenant Colonel John McCrae, Canadian Army |
#21 |
My dad's 68
67fleetside dream:my dad is a insurance adjuster and just looked at 82 hail cars...............big bad storm................I can get u intouch w/ him or...............i can read u his charts(exp:hood-1-5dents-dime sized=100 bucks)............just email me ill be glad to tell ya.........................................
Don Smith: PDR uses the glue gun on places they cant get to w/ their tools...............ive seen them do itt..............they lay the glue,stick it w/ something and pull...............needles to say it pops right out.......................................hehe that would be funny to see him mistaking it for epoxy......................I'd bet hed pull the fender off!!!.....................ohh the glue wipes of on a cloth--cool huh? I want to work as a PDR specialist when I grow older.............Im working part time for one right now dropping headliners.........................good trade I watch him all the time...........................and this dude clears over $1000.00 every day w/ expenses already paid............................WOW on headline news they said in South Dakota in 1952, there was hail the size of basketballs..................Oh Sh^t........................w/ a doubt I'd bet that would kill ya if ya got hit in the head........................and I beleive something like that would go through a house roof...........................................for more details email me at BIGGYTYME@aol.com ................................................................Jack
Jack M. 67 C-10 SWB 355 built T-350 tranny hurst shifter 17x8in KMC's on michelins, clear tails and back up lights slammed**UPDATE i have decided on my bag setup and will post further info when i recieve all the parts ****************************** 88 1/2 ton suburban 4x4 350/700R-4*having a 9 in lift w/ 38 in tires 4 12 inch Lightning Audios ****************************** 87 silverado 3/4ton jacked up 10-12 inches black and rubberized bed coating 35 in michelans ****************************** Dad's truck 68 C-10 stepside, 468 BB, tubbed, weld wheels, Nason black,lots more ****************************** grand dads truck 68 C-10 stepside fuel inj. 350/700R-4*soon in audi silver* ****************************** 84 toyota pickup 22R 5 speed 2WD slammed, shaved and all the body lines filled w/ buickGN scoop,bout to be sprayed in 2003 mustang green metallic w/ silver flames ****************************** S/N=BIGGYTYME@aol.com (hydros) "No fat chics, truck will scrape" |
#22 |
I've never used the torch and cool wet rag method....but sounds like it would work well, especially in the top of the cab where you can't hammer the dents out.
A dolly is the steel block you put on the opposite side of the dent that you want to hammer out.
#23 |
Holy Cow Pebbles, You're gonna wear out your ...... Key!
![]() I looks at the abcproromo site and couldn't find that dent removal tool mentioned.
#24 |
![]() Join Date: Mar 2000
I've never done the torch thing but I've watched it done and it definitely works. You would want to practice before starting on your own truck though. Any good older bodyman will know the mastery of the method. DON'T drill holes!
Saskatoon, Saskatchewan Canada |
#25 |
You can contact ABC products promotion via e-mail :abcpropromo@earthlink.net or phone 714-533-0802 or mail 539 East Central Park Ave. , Anaheim Calif. or use the "contact us " at the website (PDQ paintless Dent Puller)
