Old 08-03-2005, 05:11 PM   #1
c10crazy
Like a Rock!
c10crazy's Avatar
Does the cowl area have drain holes?
I took my cowl off recently to find a leak and there is a huge hole in the corner below the cowl that is hard to see but if you reach your hand back in there can feel. Looking up above the e-brake you can see day light. How the heck do you patch this? . It seems like there should be drain holes to prevent this.
69 LWB
Runs great - work in progress
Mess with me and you mess with the whole trailer park!
c10crazy is offline   Reply With Quote
Old 08-03-2005, 06:06 PM   #2
matthufham
one on each side. mine was packed full of dirt, leaves... so i drilled a 2 inch hole in the bottom so i could get my hand in there and clean it out. now i have to weld it back up.
matthufham is offline   Reply With Quote
Old 08-03-2005, 06:20 PM   #3
Harold Shepard
YOU CAN CUT A SIX BY SIX HOLE IN THE UPPER PART OF THE PLENUM AND ACCESS THE RUSTED AREAS, BUT SAVE THE PIECES YOU REMOVE FROM THE PLENUM AND SIMPLY REWELD THEM WHEN THE PATCH IS FINISHED. i RECENTLY DID THIS WITH THE TRUCK i AM WORKING ON, AND ONCE THE COWL PANEL IS BACK IN PLACE, YOU CAN NOT TELL THAT THE AREA WAS WORKED- THEREFORE YOU CAN FINISH IT AS YOU CHOOSE, THIS IS NOT A HARD REPAIR BUT TIME CONSUMING BECAUSE OF THE STRANGE ANGLES ETC. bE PREPARED TO HAVE MORE TO REPAIR THAN JUST THE COWL AREA AS THE LOWER AIR BOX (WHERE VENTS ARE) IS LIKELY RUSTED AS WELL AND THEN THERE ARE THE KICK PANELS. GOOD LUCK
Harold Shepard is offline   Reply With Quote
Old 08-03-2005, 06:49 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Mine drains right onto the cab floor.
Old 08-03-2005, 07:06 PM   #5
c10crazy
Like a Rock!
c10crazy's Avatar
Where exactly is the water supposed to drain?. Behind the fender onto the ground? . There doesn't look like room to weld unless you stand on your head!
69 LWB
Old 08-03-2005, 07:32 PM   #6
matthufham
do you have your fenders off, you will see then what we're talking about.
Old 08-03-2005, 09:03 PM   #7
c10crazy
Like a Rock!
c10crazy's Avatar
Wow,thanks for that pic!. That looks like it could easily clog with packed leaves. The fenders are still on. When you take fenders off and reinstall, are they hard to align back up??. Never did it before myself.
69 LWB
Old 08-03-2005, 09:42 PM   #8
matthufham
i shouldn't think it's too hard, there's nothing bolted to my inner fenders so those are easy to bolt up, and it alligns easy, and my outer fenders had no shims so it must not be too hard to mess up.
Old 08-03-2005, 10:16 PM   #9
sleepyboy
'69 Step
I bought a "rust free" truck from a PO. Had same issue. Cut open air boxes, did my welding, and closed them back up. Time consuming, but fairy easy once the problem(s) were isolated. I cut the bottom of my air boxes out so the water/debris exits easily. In texas, the kick panel vents are never used, constant a/c so I chose the drain issue as more important.
sleepyboy is offline   Reply With Quote
Old 08-04-2005, 08:38 PM   #10
rmrtndl
Hey ya'll, Watch this!
rmrtndl's Avatar
Looking at that pictures made me think "No wonder the rocker panels rust out!" The water runs out the drain hole, and down to the hole at the front of the rocker.
Rick M.
72 GMC SWB Fleetside
25 Chevrolet Superior Series Truck
95 Mazda Miata
06 Dodge Charger RT
http://ram92.ods.org/blog.html
rmrtndl is offline   Reply With Quote
Old 08-04-2005, 09:31 PM   #11
byrd
Union Electrician
byrd's Avatar
Mine too, it helps to get the mud off my boots after work
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 08-05-2005, 12:48 AM   #12
72str8flush
72str8flush's Avatar
Mine leaked into the floor board the day I bought the truck. I saw the big drain holes from the cowl and thought that PO was just an idiot for drilling those, now I guess others have this problem as well. I was thinking about taking some black silicone and clogging them up but I need to get leafs out of the cowl first.
72 Chevy Short Bed Fleet: 350/TH350 - Sold - Now trying to sell the parts that I have left over.
_______________________
2006 VW GTI
72str8flush is offline   Reply With Quote
