Old 08-03-2005, 06:05 PM   #1
mtdave2
newly minted old timer
mtdave2's Avatar
how to test a hei coil
anyone have a link for the testing of a coil? i think mine is dead and i have forgot how to test it.
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
Old 08-03-2005, 07:47 PM   #2
cdowns
cdowns's Avatar
you can go to most autoparts stores and they
'll test them for free
Old 08-04-2005, 08:54 AM   #3
355
355's Avatar
Pull the whole dist. out. Put a wire, like tie wire, from one plug wire post to the next and just loop them together in series, but don't connct #1 to #8 and leave a 1 to 1 1/2 foot tail on your wire. Lay the dist. shaft on your front grill support for a ground, hook up a 12v hot wire to the dist. and locate the wire tail close to your grill. Spin the gear and you should see a hard spark from the tail wire every time the rotor passes a plug terminal. Did any of that make sense?
1969 C10 Long Step,355,700r4w/lockup, HEI,Weiand,750 Performer,1.6 rockers,Camel Humps,Comp 262Extreme,Hedman,2 1/2"pipes, tele/tilt,SunRoof,ps,Disc pb,ac,Cragar,eaton,Corvette style roll pan, Bowtie louvered tail gate,lowered 2/2.
355 is offline   Reply With Quote
Old 08-04-2005, 09:08 AM   #4
Canadian72GMC
Or, remove coil, .5 ohms from primary negative to primary positive, and 8,000 to 12,000 ohms from the center button(secondary) to either the primary positive or negative terminal depending on the year of the distributor.
Canadian72GMC is offline   Reply With Quote
Old 08-04-2005, 11:00 AM   #5
mtdave2
mtdave2's Avatar
thats what i needed that canadian72gmc. i tried the part stores lol, what a waste of skin those guys are. they looked at me like i was crazy.
69 k10 Suburban
Old 08-06-2005, 10:39 AM   #6
gregbr
Senoir Member
gregbr's Avatar
Sorta agree with canadian72gmc....with the coil REMOVED, reading between coil primary leads (red & white or yellow) should be .5 ohms approx. Checking the secondary side...reading from the button to the metal coil frame or black wire (depending on the coil brand) you should have 6-10,000 ohms. Factory coil has a black lead that is grounded to the metal frame, 50,000 volt super coil does not. With the coil installed and the ignition module wires plugged up, you read the secondary to the primary like canadian72gmc said. Just went thru this myself, secondary side died. New factory type was $18 at AutoZone. Greg
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4"
70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010
70 GMC Restoration Pictures
http://67-72chevytrucks.com/gallery/...00&ppuser=4424
gregbr is offline   Reply With Quote
