Old 08-03-2005, 09:09 PM   #1
fade94
fade94's Avatar
Question Putting leaf rear on coil rear frame?
I am getting a 69 short frame that I will be putting my 71 stuff on. However, the 71 is a leaf rear. Does the 69 frame have the holes for the leaf mounts? Has anybody done this swap? Got pictures? How about pics of a 69 frame, rear section, side view.
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates)
67 short step project (will get SWB from the 68)
67 Camaro, #'s matching (my wife's)
03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear
fade94 is offline   Reply With Quote
Old 08-03-2005, 09:37 PM   #2
72402
Don't have pictures and not sure about the holes, but the frames are the same. Even if you have to drill the holes, it shouldn't be a big deal. You can make a template off your old frame if you need it.
72 Cheyenne SWB Fleet/original 402, TH400, buckets & console
65 C10, 350TBI, 700R4 (work in progress)
72402 is offline   Reply With Quote
Old 08-04-2005, 12:15 AM   #3
GloryHound
Working on a Nova.
GloryHound's Avatar
The Holes should be there! Just use 8 grade hardware. The frame rails were mass produced to accomidate either suspension set up. The coil spring set up is close to a Nascar set up and better for hot rods while the leaf spring is more stable with a load or when towing.
GloryHound is offline   Reply With Quote
Old 08-04-2005, 01:20 AM   #4
SCOTI
SCOTI's Avatar
I seem to recall some 'beads' in the frame rail/s that surround the front leaf hangers on my leaf equipped frame that arent there on my coil equipped frame. In other words, leaf frames have slightly different reinforcements where the leaf specific mounting brackets go. Other than that, they are the same (shape/width).
I could prob get some detailed pics to show what I'm referring to if my description was clear as mud.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-04-2005, 01:25 AM   #5
lloyd k
lloyd k's Avatar
youve got to take the bumpstop bracket off,im pretty sure its on the outside of the rails
67 swb gmc,big block cadillac powered,400 turbo,2.73 ratio and disc brakes-basically a frankenstein of many parts-
lloyd k is offline   Reply With Quote
Old 08-04-2005, 05:26 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I just have to ask....WHY would you want to go to leaf springs???
Old 08-04-2005, 07:14 AM   #7
Joe67
67 is sold
That is what I was thinking, just get a rear coil frame and enjoy the ride
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 08-04-2005, 07:51 AM   #8
fade94
fade94's Avatar
The reason for the switch is this. The 71 is a long bed with leaf springs and I want a short bed. The 69 frame is stripped bare which is ok, since the 71 is a driveable truck and I am going to put the body on the short frame. I have located a bed already so I just need to switch my stuff over. Other than the leaf spring mounting and the breake lines, it should be pretty straight forward.
I am getting this frame for a good price. (thanks huggercst!) I have located a short coil frame but it has a 6 lug rear and is way more than what I am buying this frame for. I will also be pulling a trailer with this truck and the leafs will definately help out in that area.
Scoti- pics would be great. You are correct about the beads on the frame rail on each side of the leaf bracket.
Old 08-04-2005, 08:00 AM   #9
Joe67
67 is sold
Gotcha. Hopefully everyting you need to transfer it over is there already
Old 08-04-2005, 08:09 AM   #10
fade94
fade94's Avatar
part
I drive the 71 now, so swapping should only be a weekend thing that my son and I can do. I will pull the front clip as a unit. Pull the cab. Pull the motor and trans and go ahead and replace the gaskets on the motor with FelPro Permadry gaskets (leaks now). Then pull the bed. I will just unbolt the front cross member and bolt in under the 69. Then mount the rear. Then swap over the brake lines and wiring. After that, its' motor/trans, cab, clip and mount the fuel cell then put the bed on.
The 71 is in awesome shape except for the bed and the ORANGE paint... It has a speed warning inst panel in it. I am trying to figure out how to get it working (missing cable and harness for it) or may trade it for a tach dash.
Old 08-04-2005, 08:46 AM   #11
mocwon
Keep On Truckin'
mocwon's Avatar
I did this swap and everything was not there. I had to drill many holes. This could be because I started with a 72 GMC leaf long-bed and swapped everything over to a 69 Chevy coil short-bed. I don't know enough about these trucks to say for sure. Just used the old frame as a pattern to measure where all the holes would need to be.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 08-04-2005, 09:18 AM   #12
fade94
fade94's Avatar
How did it turn out? Got pics?
Old 08-04-2005, 10:06 AM   #13
mocwon
Keep On Truckin'
mocwon's Avatar
Everything turned out fine. I've posted pictures recently of the truck assembled. Look for the post by MOCWON to see the results. I'll try to post pictures tonight of the frame but they are only pictures of the completed rolling chassis.
Just Passin' Thru
Old 08-04-2005, 10:34 AM   #14
mocwon
Keep On Truckin'
mocwon's Avatar
I found a picture on this computer...
Just Passin' Thru
Old 08-04-2005, 01:04 PM   #15
Longstep70
Junior Member
I dont want to hijack the thread but i'm curious; how hard is it to go the other way and convert a leaf frame over to coils? Are the mounting points for the trailing arms on the leaf frame crossmember?
Longstep70 is offline   Reply With Quote
Old 08-04-2005, 02:53 PM   #16
fade94
fade94's Avatar
I think the mounting points are there. There are some holes on the cross member.
Old 08-04-2005, 03:28 PM   #17
72MARIO
72MARIO's Avatar
My frame has the 'beads' SCOTI was talking about. Pretty sure coil truck do not have those reinforcement's.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 08-04-2005, 04:16 PM   #18
69 Short Fleet
The leafs are great when your hauling stuff or towing and GM made an optional leaf spring helper to add to that (their getting hard to find now though) so I think your plans are good for what your going to use your truck for.... on the other hand my short fleet with leafs (no load) kicks like a mule going over speed bumps or uneven pavement....
69 Short Fleet is offline   Reply With Quote
Old 08-04-2005, 04:20 PM   #19
fade94
fade94's Avatar
Like a mule...
It's always something isn't it?...
Good ride, not so good for hauling....
Rough ride, good for hauling....
If I had a short coil frame with a 5 lug rear, that would be ideal. But I don't. So, I either have to modify a coil frame to accept my rear, OR, cut the long frame I have now, down to short bed length....
Since the deal I had working for a frame just fell apart, I am now looking at cutting my frame down.
Old 08-04-2005, 04:50 PM   #20
67ChevyRedneck
67ChevyRedneck's Avatar
I don't know if the holes are there or not, but the cross-member you are referring to is specific to coil spring trucks only. You will need the cross-member and trailing arms off a coil spring truck along with the mounting locations, so, no, there is no cross-memeber on a leaf frame that will work with coils, you have to add it. I guess you would also have to add the perches that the coils sit in to the frame as well.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 08-04-2005, 06:17 PM   #21
SCOTI
SCOTI's Avatar
PM sent.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-04-2005, 08:21 PM   #22
Longstep70
Junior Member
Thank you. Good info.
