Old 08-04-2005, 12:08 PM   #1
a417latino
1956 chevy pickup flatbed frame 3/4 ton
Can I use a chevy pick flatbed frame on a regular 1956 chevy pickup shortbed 3100? if so, what kind of modification do i need to make on the frame. thanks eveyone!
a417latino is offline   Reply With Quote
Old 08-04-2005, 02:38 PM   #2
1-ton of fun
polishing a turd
1-ton of fun's Avatar
what year is the frame from?
1-ton of fun is offline   Reply With Quote
Old 08-04-2005, 08:20 PM   #3
a417latino
The frame is from 1955 with a dually rear end and 18" wheels / tires.
Old 08-05-2005, 04:47 PM   #4
1-ton of fun
polishing a turd
i would think it would work. at least the cab and front clip.
Old 08-11-2005, 06:28 PM   #5
Norselander
Clunker Farm, Proprietor
Norselander's Avatar
A 3/4 ton frame can be made to fit -- you'll have to cut about 9 inches out of it behind the rear cab mounts so that it matches the 114" wheelbase of the 3100/31. That's if the frame really is a 3/4 ton frame and not a 1 ton frame. The one tons had a longer wheelbase than the 3/4 tons. And as I recall, the frame channels are taller between the front and rear axles.
Note that the heavier one ton frames DO NOT have a hump above the rear axle whereas the lighter trucks do.
Drew
Chief Junk Jockey
Norselander is offline   Reply With Quote
