Old 08-04-2005, 01:00 PM   #1
jd4300fel
jd4300fel's Avatar
ignition switch removal?
pretty much what the title says how do you remove the ignition switch
from the dash?
I am gutting the cab of a 72
thanks
Mike K
Friend of Bill W
jd4300fel is offline   Reply With Quote
Old 08-04-2005, 01:17 PM   #2
jhow66
jhow66's Avatar
Use a paper clip and insert in hole in switch. With key turn switch to ACC and pull out tumbler. Unscrew bezel by using the 3 notches. Unplug wires from switch.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 08-04-2005, 01:58 PM   #3
pjmoreland
pjmoreland's Avatar
If you don't have the key, you can pop the sheetmetal faceplate off the front of the tumbler, and drill a 3/16" hole into the tumbler to the left of the key slot. Drill at a slight angle so that the hole breaks through the left side of the tumbler. You can access the locking mechanism with a small screwdriver.
pjmoreland is offline   Reply With Quote
