'68 C-20 396 CST CC
![]() Join Date: Mar 2005
Seam sealer for driprail...
What should I use to replace the old crusty seam sealer in the drip rails? Is it the same stuff GM used between body panels?
68 C-20 396/TH400 CST Custom Camper NOW W/DISC BRAKES ![]() 01 Jetta Turbo Daily Driver ![]() 84 Yamaha Virago 700 - Alaska to Florida Via Maine & Mexico ![]() |
Here are a couple of posts:
http://67-72chevytrucks.com/vboard/s...threadid=62420 http://67-72chevytrucks.com/vboard/s...threadid=93910
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
'68 C-20 396 CST CC
Thanks neonlarry!
Keep On Truckin'
We use 3M panel bond adhesive. This stuff works great, is self leveling, dries hard as a rock, is sandable and seals out moisture. It's expensive and takes a special gun but is a forever fix.
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
More Cowbell....
I just used the 3M seam sealer that comes in the caulk-gun tubes. About 1/2 a tube did the entire driprail, and the all the seams in the floor that run across & around the firewall. Dries hard, so I can sand it perfectly smooth (no more finger marks or high/low spots) in the drip rail before painting....or in my case...sealing/priming!
It's the white strip you see. I might hide it under another layer of orange epoxy sealer. (Sorry I don't have 'drip rail' pics handy?!?!)
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket Last edited by Putter; 08-04-2005 at 03:16 PM. |
Thanks for showing that product now MOCWON.... just kidding.
That looks likle a great product to use wish I would have came across that before now. It's just that my new GM seam sealer has already cracked in a couple of spots. I am pretty fustrated it's impossible to fix. With out repainting the entire cab.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Keep On Truckin'
This stuff is supposed to be very good although I have no first hand experience with it.
3M claims: "Automix Self-Leveling Seam Sealer is applied directly over primed metal and matches OEM seams with no shrinkage or cracking."
my gas saver
here's the stuff all of my buddies use it's called "fusor" (we get a discount
85' SWB, 4.3/TH350, getting ready for paint 84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black 71`SWB, project ebay feedback |
I used 3M drip chek and it worked great. Took about 2 tubes and it's self leveling.
1980 Chevy Shortbed Pickup 1969 Z28 engine Turbo 350 |
I have a tube 3m Drip Check and a tube of 3m Fast n Firm. I have not tried either yet but it is what the paint store recommended.
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
Jwil41,
We have done several cars/trucks using 3 M's Fast and Firm and results since about 2000 have not been good. Every truck/car that we have used it on has cracked since then. It makes you sick to see it happen. We have some restored cars/trucks that we did 15 years ago using 3 M Fast and Firm and the seams have not cracked. I cannot prove the product has changed but we cannot make it work anymore. We have been expermenting with other seam sealers hoping to find something that will last. Time will tell but I would suggest that you use the products that members have had some long term experience with. Jim |
Thanks for the heads up. When the time comes I will do a little more research.
