18436572
WTB: front crossmember
If anyone has an already modded front crossmember to lay rocker or frame for a 70' 2wd C10 forsale let me know. I can use my stocker for a core if needed.
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
I can build you one if you are interested. It would take about 4 weeks from the time I get it.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
18436572
What would be left to on my part after you mod the crossmember?
Do you think i might need to notch the frame for the steering? I've got the ECE 4/6 drop with their disc conversion on the truck if it matters. |
Active Member
contact Jeff at KRZ customs... he will section it for you for 100 bucks. Atleast 2-3 years ago thats what he was going to do it for me for. And yes, you have to raise your steering linkage up as much as you section your cross member to keep the right geometry. Then notch your frame accordingly.
#5 | |
http://67-72chevytrucks.com/vboard/s....php3?t=137398 You will need to modify the steering linkage, (borgensen joints) and notch a few places for clearance on the crossmember. (see above) As for notching the frame for clearance, not unless you go more than 1.5".
18436572
Thanks, this swap shouldn't be that hard from the looks of it. (famous last words)LOL
#7 | |
Seņor Member
![]() After all the dust settled, my front notch cost me < $2k. That's rounding up an xmember, Captkaos mod, shipping both ways, new bags and plates, new ART control arms, Borgeson parts, and some labor. Subtracting the ART control arms would put everything < $1k.
Active Member
he was just asking about getting a crossmember cut, welded back together, done. I don't see why it'd be so expensive...?
#9 | |
Never Done?
![]() Join Date: May 2000
#10 | |
Seņor Member
Active Member
"If anyone has an already modded front crossmember to lay rocker or frame for a 70' 2wd C10 forsale let me know. I can use my stocker for a core if needed." the original question is what I was reffereing too
#12 | ||
For the amount of work I have to do to eliminate all of these problems where you just have to have a crossmember and everything that was there before (minus steering section) to bolt up, I actually could charge more. Quote:
I wouldn't cut one for just $100, the core cost me almost that much.
#13 |
Active Member
nope, you bring him your crossmember, he sections it just like all you guys are reffering to here. Take a 1.5" section out of the whole crossmember, weld it back together and make it look nice all for $100. And no he is not using anyone elses stuff. He makes everything in house and does his own machining. Check out his website, asyou will see, he does very nice work. I guess I should just keep my sauggestions to myself
#14 |
Hell, that seems cheap to me. I did my own and I know if I did it again I would charge a hell a lot more than $100. Sounds to me like it would be a halfass job for $100. Just fyi, plus captkaos has a good rep on this forum and can be trusted.
66 C10 (under construction) 1.5" crossmember drop 2" Z'ed frame 8" rear notch Watts-link Bagged DJM 3" spindles |
#15 |
$100 is cheap, if you can get it done for that, well....
BTW, I charge $385 for this plus shipping and core charges for comparison. This is about the same Turners charged for his setup, but you WILL get it, as turnaround is 4 weeks depending on who supplies the core. Thanks for the Props XXL and DM310.
#16 |
18436572
It may cost me, but i want it done right the first time as it'll have to hold up to constant use. Probly as a daily driver, something to haul my Busa to the track and parts hauler for my motorcycle business.
I've seen WAY to many hacked up air suspensions in the past at shows. Some setups make you wonder how they were even being driven without falling apart. For the guys that take the time to do stuff right, my hats off to ya. Last edited by Truckhead; 08-09-2005 at 05:34 PM. |
#17 |
Use a fat man fab front end, comes with rack, complete suspension and bags. Lays frame, tucks the wheels in, gives major clearance and saves about 100 lbs up front.
A buddy of mine started with the cut cross member and all the other stuff, then sold that and did the fat man swap. easy, steers and drives great and bolts in just my one penny's worth plus cleaned up the look of the front end with the polished a arm's |
#18 | |
Seņor Member
#19 |
JUNK COLLECTOR!!!!!
![]() ![]() The dark side! 2000 XLT PSD F-250 4x4! Offroad package 1970 C10 Short-step soon to be short fleet, maybe? Corvette in truck's clothing in work! Corvette IFS, IRS, TPI and Doug Nash 4+3 |
#20 |
I'm going to get flaq for this but why dont you consider "z"ing the frame. All the steering stays the same and if ur not going to run a big wheel u won't need to z it that much. That's just something else to throw at ya
#21 |
Epoxy Primer Friendly
I called Jeff at KRZ customs and he says he doesn't do the X-members anymore.
#22 | |
Seņor Member
#23 |
Active Member
well like I said, 2-3 years ago I got that price. I was just throwing it out there...
#24 |
I didn't mention a price to him, just asked if he did them, and the answer was no. Anybody else do them ?
#25 |
Active Member
by the way, where is everyone located?
