Nothings as cool as my 72
Sandblasting spindles
I know you can't sandblast the part of the spindle were the brake disc goes on but I was wondering if I cover that part up if it would be alright to sandblast the rest of the spindle. I wan't to have all my suspension pieces sandblasted, sprayed with primer and painted black, so if there is anything else I should know about the other suspension components before I start doing it this weekend.
1972 C10 Longbox In the middle of body off restoration Rebuilt 355, turbo 400, 3.42 12-bolt Rolling chassis finally done and cab mounted. Now onto sanding, bondo and more sanding. ![]() |
Captain Ed
Yep, blast away.
its all about the +6 inches
Use duct tape to cover the spindle.
#4 | |
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
Working on a Nova.
might want to plug were the balljoints and tierod slip on that is a machined surface also.
Thanks. I got to find out wut is wrong with my sandblaster, it wasn't working today. Maybe I should drain out the old sand and put in new stuff. It has been only sitting in there for three days put i collects moisture in there because i have a pretty funky compresser setup. The tank is and old propane tank the we convert to work as a holding tank for the compresser and sometimes the air still smells like propane.
Is there anything else i should mask off. Also is it hard to replace the ball joints and rubber bushings.
