Old 08-04-2005, 08:13 PM   #1
va3jco
tires and lift help plez
can anyone tell me how much of a lift i need to get 33" and 35" tires under a 1984 chev 4x4 with out having rubbing problems??
va3jco is offline   Reply With Quote
Old 08-04-2005, 10:05 PM   #2
uncle_handsome
Uncle H. is this cartoon
uncle_handsome's Avatar
From what I've heard, a six inch lift should be good enough for even 35's on a 73-87 GM.
uncle_handsome is offline   Reply With Quote
Old 08-04-2005, 10:22 PM   #3
drink2mny
drink2mny's Avatar
I moved ya over here to the 4x4 board..
I've heard both..
You could have 35x 12.50's with a 4" but might still hitthe fenders..33's would fit fine with a 4" Heck even a 2"(re arched front springs and Add a leaf in the rear..
A 6" would be the safest.. for 35", but you'll have alot more stuff to modify going with a 6" driveshafts, brakelines..
Also welcome to the board..
Support The Board
drink2mny is offline   Reply With Quote
Old 08-05-2005, 10:45 PM   #4
see ten
WTB this ad
see ten's Avatar
A lot will depend on your wheels and their offset. I ran a 33x12.50 all terrain on 8" rally wheels on my 84 Silverado with no lift and never had any problems. I used it this way for several years and the guy I sold it to is still running it that way. I should mention that I never really had it in a bind off road.
see ten is offline   Reply With Quote
Old 08-05-2005, 10:51 PM   #5
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
2 THE BOARD FROM WEST 10-UH-C
My rig has a 4" F / 6" R spring lift and I'm running 35's
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 08-06-2005, 12:14 AM   #6
a28doc
'87 V20 4x4
a28doc's Avatar
Im running 35's under a 4" lift myself with no probs so far but I also havent had it hardcore wheeling yet either since then
Doc
'86 K5 Blazer 4x4 FOR SALE
'87 v20 4X4
'99 S10 Blazer 4X4
a28doc is offline   Reply With Quote
Old 08-07-2005, 09:21 AM   #7
va3jco
Thumbs up
thanks for the info guys, going to run 33 12.50 16.5 : on 10" wheels i think 35 are going to be hard to turn i think and going with a 2.5" lift i think at least thats the plan once again thanks for the info. trying to find guys in ontario with parts for sale as i live near ottawa.
Old 08-07-2005, 09:40 AM   #8
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Yeah, 4" should be fine for 35"s. You just got to decide if you want to run 33"s or 35"s.
-Later
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 08-07-2005, 07:41 PM   #9
ben@speedbarn
Done yet?
ben@speedbarn's Avatar
Yeah me and a few others around me run 33s with no lift. No problems.
'76 k2500 -- almost done...
ben@speedbarn is offline   Reply With Quote
Old 08-07-2005, 10:39 PM   #10
CyberRanger
CyberRanger's Avatar
How much tire you can run depends on 3 things... tire width, wheel offset, & lift. You can run a taller, narrower tire w/ no lift than the same height, wider tire.
For example (this works on most other 4x4s other than just mine)...
I run 36" tires which are 11.50 wide w/ a 4" lift. To run a 36" tire which is 14.50 wide requires a 6" lift w/ a lot of fender trimming or an 8" lift w/ the same fender trimming I have (almost none). Also, you can run a taller tire if it is kept under the fenders (i.e., very little positive offset, 0 offset or negative offset) than if you run the same size tire w/ lots of positive offset (movin' the tire out away from the axle). The right width & offset wheel can make the difference between bein' able to run a tall tire or havin' to settle w/ something shorter & wider.
'71 K20 Custom Deluxe - 1 owner - Original 350 & 4 spd, Rams horn dual exhaust, Centerforce clutch, K&N 4"x15", factory tow hooks, 4" Skyjacker Softride, Rancho RSX9000s, custom Firestone AirRide overloads, 36" 305/85R16 10ply Buckshot Mudders, 4.11 gears
CyberRanger is offline   Reply With Quote
Old 08-08-2005, 12:49 PM   #11
Superron21
DONT TRY THIS AT HOME!
Superron21's Avatar
be careful offroading with 16.5 tires, they dont have the grip on the bead that a 15 or 16 inch wheel has, and if you air your tires down without beadlocks you are just asking for trouble. they would do fine as pavement pounders
Superron21 is offline   Reply With Quote
Old 08-08-2005, 07:32 PM   #12
va3jco
well maybe i won't run 16.5 in that case, ill try to find 15" whells that are 10 or 12" wide then maybe 16" rims but 15" are more popular.
thanks for the heads up same me time and money later i hope.
Old 08-09-2005, 02:54 AM   #13
Mudder
Mudder's Avatar
Lately 16" seems to be more common.
Mudder is offline   Reply With Quote
Old 08-13-2005, 06:15 AM   #14
vtblazer
vtblazer's Avatar
My .02
33's with a 4" lift work fine even off road
35's, I'd go with a 6" lift for any kind of 4x4ing
I've run both 8" & 10" wheels without issue's both sizes had a 4" back spacing
I did run 35's on a stock 78 3/4 ton 4x4 but it was close.
vtblazer is offline   Reply With Quote
