![]() Join Date: Apr 2005
Scccooooooorrrrrrrrrreeeeeeeee!!!
Just got my new body bushing kit from Energy Suspensions (ordered through Summit part #3-4149). They come in red or black and were only $115 shipped, complete with all hardware!!!!!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
![]() Join Date: Dec 2000
Just ordered mine....presently backordered until September.
Thanks!! Doc
1970 Sub C-10 - 350/TH-350/3.73 12-bolt Came home from the hospital in it & mine ever since. 1966 Catalina Ventura 2-door fastback 389/TH400 Last edited by doc70sub; 08-04-2005 at 10:38 PM. |
sweet! for the suburban!?!? no way!
thanks! |
All Praise RANDY!!
Did you have to order over the phone?, I cant find it online at all?
HEEEEELLLLP! NutZ |
All Praise RANDY!!
Ok, I found it, but what part # is the red set? is it ens-3-4149g or is it ens-3-4149r....?
All Praise RANDY!!
Hey, Jegs has it too for $106.99 might be cheaper TO you from them as well...
part #355-3-4149R Sweeeeeeeeeeeeeeeeeeeet! |
g is black and r is red
70 k20 'burban (latest aqusition) 91 k1500 xcab lb 99 f350 (sold) 83 cj7 (huge and for sale) 82 rx7 (auto-x project) 74 VW superbettle 04 summit 800 151 & 05 renegade 600 guns, flying, camping, biking, 4-byin, bbq's and beer! |
The "g" should also stand for graphite impregnated (in a black color). Should cut down more on squeaks.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
4X4,
Do you think the red will squeak more? Rob
I should have said that the graphite is designed to reduce any squeaking. I haven't tried poly body mounts (red or graphite) on a 2wd, so I don't even know if they squeak if lubed a little when installed on a 2wd. 2wd frames don't suffer the movement 4x4 frames do or leaf-spring, A-arm, trailing arm, or swaybar bushings do, so if the poly mounts will squeak, it can't be much. Poly body mounts can squeak, but I know that as a 4x4 concern off road when the ladder frame flexes more than a 2wd frame does on road.
Is it worth the shipping to exchange? Can't say I know for a 2wd. I would recommend it for a 4x4 if the budget allows, but that's just my opinion. And I strongly recommend graphite impregnated poly for suspension locations. Lube, too. For instance, on my Land Cruiser, I have graphite poly spring bushings with greasable shackles and spring hanger pins that are quiet. The latter two are items 2wd truck users don't normally use though A-arms often have bushing grease points. Before that I just had red poly spring bushings and they did squeak, but that's suspension apples and body mount oranges. Just as unlike with 4x4 trucks, frame twisting is not usually a 2wd concern. So, I think I made my above post from my 4x4 perspective. Sorry about that. I sometimes forget that most board members are 2wd truck owners.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. Last edited by 4x4Poet; 08-07-2005 at 06:03 AM. |
