Old 08-05-2005, 09:41 AM   #1
RJ Swanson
RJ Swanson's Avatar
Temp Gauge Troubles
When I take the wire off the sending unit and ground it out, the needle moves 3/4 of the way across the gauge.
(I think this would indicate that the gauge is OK?)
I also put in a new temp sensor between the #1 & #3 spark plug. I did not use teflon tape as not to interfere with the ground. Still the needle only jumps when I turn the key on and nothing after that.
Any other Ideas that could cause my temp gauge not to work?
RJ Swanson is offline   Reply With Quote
Old 08-05-2005, 09:48 AM   #2
kaycee
kaycee's Avatar
Has that wire to the sender been burnt and spliced before?May need to run a new wire.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 08-05-2005, 12:44 PM   #3
RJ Swanson
RJ Swanson's Avatar
Spliced Wire
The wire was broken so I spliced in a new one, I used a much heaver gauge wire however, could going from original size to large size back down to original size be my problem?
Old 08-05-2005, 01:30 PM   #4
jtminton
II Timothy 4:2
jtminton's Avatar
I have a question about the gauge. If you are looking at the back of the gauge, which post is the 12v and which one is the sender?
72 C-20 2WD LWB Custom Camper Deluxe 350 4 Speed "Project Lazarus"
MY TRUE PRIDE AND JOY
"Dangit, Bobby, people will see that oil stain and think I'm a drunk."
jtminton is offline   Reply With Quote
Old 08-05-2005, 01:39 PM   #5
RJ Swanson
RJ Swanson's Avatar
With the key off, both posts are dead.
With the key on, both posts are hot?...could it be my circuit board?
Old 08-05-2005, 01:41 PM   #6
another thing that it might be is they gave you the sensor for an idiot light dash instead of the gauge model. They do make a difference.
Old 08-05-2005, 01:52 PM   #7
john
member #16
john's Avatar
[QUOTE=RJ Swanson]When I take the wire off the sending unit and ground it out, the needle moves 3/4 of the way across the gauge.
Actually the guage should peg on the hot side. I would check further into sender wire. Possible bad ga. also. Plus check sender # as was mentioned. John
john is offline   Reply With Quote
Old 08-05-2005, 04:57 PM   #8
jtminton
II Timothy 4:2
jtminton's Avatar
Anybody?
Old 08-05-2005, 05:39 PM   #9
RJ Swanson
RJ Swanson's Avatar
Possible Cause
I did a little more research...
I bought the sensor at NAPA they have the same part number for the light and the gauge sensor.
I called a few other parts stores and they have two different part numbers and prices for the two sensors
I guess sometimes even the experts can be wrong
