Old 08-05-2005, 10:45 AM   #1
fade94
fade94's Avatar
350 to straight 6 conversion...
I have a 6 cyl out of an old parts truck that I want to put in my 71 while I have the 350 out. I have the motor mounts that were on the motor, but not the frame mounts or towers. What do the frame mounts look like? I have a set of V-8 mounts from a 72 I would trade locally for the 6 cyl frame mounts if this is what I need. I am pulling the motor to clean it up and replace the gaskets and do some engine bay detailing. But, I still need to be able to drive the truck, and let's face it, gas ain't cheap. The six "should" get better mileage...
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates)
67 short step project (will get SWB from the 68)
67 Camaro, #'s matching (my wife's)
03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear
fade94 is offline   Reply With Quote
Old 08-05-2005, 11:30 AM   #2
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Yes and no,
My 250 only gets 13mpg at the moment, my 283 probably will do the same or better since I regeared the rear end. I wont know till she is running soon. Ill take a picture of my mounts for you today. Remember that if your truck was a stock eight (check the vin for a cs=6, ce=8) youll will have to move everything to the rear for the 6 to fit, also is yours a 3 speed or auto, the 3spd crossover mount is different for each engine, auto shouldnt be hard to move, the drive shaft will need to be shortened (maybe) if its swb truck. I have converted mine from a 6 to 8 and made it look like stock, (no half assing) all the parts were changed. 6 has a different fan shroud too.
Let me know if I can be any help
Bottom line, if gas is the reason, you can get more mpg out of the eight if you change the trans or regear the rearend, youll have to give and take, the 6 will be less hp and torque, but if the drivetrain is not changed youll only gain a couple of mpg.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 08-05-2005, 11:37 AM   #3
fade94
fade94's Avatar
Truck was factory 6 with 3 spd. Now has 350/350 with 3.08 rear. I WISH it was a short bed, but it's a long. No shroud on it. I have dual electric fans. I don't want to change the trans or rear gear on this truck. Not concerned about HP and Torque since I also have an 01 Dodge Diesel that will pull whatever I hook to....FOR SALE...
My work drive in only 8 miles round trip. The motor that is in now seems to really be a gas hog so the 6 HAS to get better mileage. Of course, a lot of the problem is my right foot.
Old 08-05-2005, 01:50 PM   #4
matt67350
matt67350's Avatar
I have a set of I-6 motor mounts, will trade for the v-8 mounts
69 swb stepside, rebuild and upgrade in progress
matt67350 is offline   Reply With Quote
Old 08-05-2005, 02:01 PM   #5
dave666693
dave666693's Avatar
what rear end gears do you reccomend for the best mileage?
dave666693 is offline   Reply With Quote
Old 08-05-2005, 02:17 PM   #6
fade94
fade94's Avatar
Are you going to be on this side of the metroplex this weekend? I should have pulled the frame part of the mounts off of the truck I got this out of, but I thought my brother was going to use it for a horse walker. Since he doesn't need it, I though I would stick it in to up my mileage.
Old 08-05-2005, 04:44 PM   #7
HeavyD
HeavyD's Avatar
You want to put in a 6 just temporarily? IMO it isn't worth the hassle of switching it all around. Mileage won't increase by much if any, since the old sixes are not like a fuel injected 4.3 of today. I have a 250/3 spd in my GMC and it is not good on fuel at all. You might be better off seeing if you can get any V8 (267, 305) real cheap to throw in there for the time being.
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 08-05-2005, 06:58 PM   #8
68speedalert
Semi-Senior Member
68speedalert's Avatar
Heavy D is right. I've got the same truck and gears in my '68. When I ran the 350 with 4v, it was a gas hog. When it popped, I 'temporaily' put in a '77 305 with a 2v. It now does better on gas than anything I own (sad part) and ain't bad on performance. It runs so well I haven't touched the 350 and it's been almost 5 years now.
The six is REALLY gonna suck gas when you try to make it run like the 350 did. Those sixes were never know for their economy.
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre
'83 Jeep CJ-7, <80,000 miles, original owner
'04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer
'95 GMC K1500 Extended cab
68speedalert is offline   Reply With Quote
Old 08-05-2005, 07:01 PM   #9
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Hmmmm, I had a 70 w/ a 250 mated to a 350 turbo, 4:10 gears, and got 20 MPG
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 08-05-2005, 09:01 PM   #10
wichitawings
engine conversion
I changed from a 250 6 cylinder to a 350 and I didn't have to change the motor mounts (I was able to use the 6 cylinder mounts). The 350 was pretty close to the firewall but it worked and everything lined up (I didn't have to get a new driveshaft or move the transmission even.
I did get the v8 mounts later and move the engine/trans up and got a lengthened driveshaft.
But I had an automatic and a shortbed.
By the way my 350 gets the same mileage as the 6 cylinder which was in good shape still
wichitawings is offline   Reply With Quote
Old 08-05-2005, 09:29 PM   #11
71meangreenc10
I m running 2.76 in my truck (came with 3.73), I want to change it to 3.08, 2.76 is great on the highway, engine runs smooth and low rpms at high speeds but it has no take off with that range, I may put in 3.08 and see if that helps with some torque. A 2bbl would give you better mpg but would have less hp,,,you have to pick your poison also 2.76 will through your speedo off, thats why im using dakota digital, i can run anything and recalibrate my speedo.
Smitty
71 C30 Wrecker
Old 08-06-2005, 08:42 AM   #12
68speedalert
Semi-Senior Member
You're supposed to divide the MILES by the GALLONS, not the other way around!
Seriously, that's amazing. The only time our kind of trucks get into the 20's is by being towed for half the miles!
