Old 06-26-2002, 03:54 PM   #1
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
Gettin to the fender Emblem..
I want to remove the fender emblem on my 68(/10) without having to take of the whole fender...can I just take out the fender well and reach in to unscrew it? I just want to take it off and clean it up, and put some nice red paint on the bowtie. And leave it off until I get the paint on. LET ME KNOW!!!!!!!
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
Old 06-26-2002, 04:02 PM   #2
Low69CST
If you really wanna get it off your best bet would be to drop the fenderwell down. You should be able to get to fine then. You could just tape up the fender itsself around the emblem and clean it up without taking it off. Line the fender good with paper so you won't get any mess on it.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 06-26-2002, 05:34 PM   #3
SWINGSAX68
SWINGSAX68's Avatar
drop well
ok....So say I unscrew the bolts from the outside edge of the fender well, what other bolts are there to take off? Will it just come right down, will I be able to remove the well with the wheels on? thanks!!!!!!!!!!!
"F#$@ 'em up!!!!!!"
TRUCKY LINKS
Old 06-26-2002, 05:48 PM   #4
Super Chevy
Super Chevy's Avatar
i think you might juse be able to pull the cowl off,its infront of the cab,behind the hood,its held on by like 6 bolts...
SC
Super Chevy is offline   Reply With Quote
Old 06-26-2002, 06:14 PM   #5
bigvinnie
bigvinnie's Avatar
removing the cowl won't be enough..... you'll have to remove the bolts where the fender lip meets the inner fender, all the way to the bottom rear edge of the fender.... then loosen the ones at the core support and the large one where it bolts to the cab and you should be able to access the emblems...
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 06-26-2002, 06:47 PM   #6
HvyChevy454
Slowly getting CRSS...
HvyChevy454's Avatar
if your talkin about the ones by the door to get em off you have to remove the fender well and i am able to get if off w/ the 235/70 15's still on. putting it back on is another story i had to loosen up the back portion of the quarter panel and have my dad pull out on while i stuck my hand up in there to start the new threads. besides taking the fender wells out is no big that is the 1st thing i do when i have to do any work in the engine bay b/c it gives you so much more room to move around.
-Nic
Lutz, Fl
My Team Website
The Heavy Chevy Website
  • 72 Cheyenne 10 LWB GM 12-bolt 3.08 w/ Auburn Posi
    91 454 Edel Performer RPM Intake 750 cfm carb Comp Cam 268/.495 Hedman Headers Dual 3'' Exhaust
  • 71 Cheyenne 20 4x4 Fact. A/C PS PB Tilt Currently in the works...
Speak Softly and Carry A Big Block...
There is No replacement for Displacement...
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
HvyChevy454 is offline   Reply With Quote
