Old 08-06-2005, 12:00 AM   #1
Chevy_Man
Tightwad
Chevy_Man's Avatar
Need help
I have gotten a complete truck for parts , just not sure what i got , the cab is a 67 and the front cap is 69 or 70, it has disk brakes on the front but the brake master has no booster. Is that possible? i am wanting to use these spindles and stuff for the front so i can have disk brakes on my 68 . would a brake booster work with this? Or maybe the people never finshed the truck? any ideas? any thoughts would help!!!
Thanks, eric
Chevy_Man is offline   Reply With Quote
Old 08-06-2005, 12:10 AM   #2
matt67350
matt67350's Avatar
Post some photos of the truck.
Boosters can be installed with out much trouble.
Good luck
Matthew
69 swb stepside, rebuild and upgrade in progress
matt67350 is offline   Reply With Quote
Old 08-06-2005, 12:18 AM   #3
Chevy_Man
Tightwad
Chevy_Man's Avatar
The truck that i had got for parts had all this on it without brake booster, just master is all and disk brakes, i guess what i mean is what year did they start putting disks and did they use brake booster when they started, next question is could i put all this on my 68 and use a brake booster with those callipers?
Old 08-06-2005, 12:21 AM   #4
longhorn71
longhorn71's Avatar
71 was the first year for disc brakes.Not all of the trucks with disc brakes had power brakes that was an option.I have a 71 here with no booster and it was built that way
longhorn71 is offline   Reply With Quote
Old 08-07-2005, 05:42 AM   #5
jlmtrout
This is an easy, straight-forward swap. I bought complete frontend, spindles,rotors,calipers,upper and lower control arms, center link, pitman arm and rear end at Super Chevy Weekend, for $125.00. Only drawback to installing on my '68 was the 6 bolt lug pattern. (Two spares) I bought some stronger-than-stock 5 bolt axles from Summit for around $200.00. This is also an easy swap. Another benefit of this swap is a greater selection of wheels. Good luck and keep on truckin'..................Jerry
'68 c-10 long wheelbase fleetside, been in family since new, originally 250 3 speed
Now (389) 350 .060 over 3.75 stroke,Edelbrock Performer RPM 70cc heads and Intake
600 cfm Edelbrock,Small Comp Cams retro-roller cam and roller rockers,9:1 cr, headers, HEI,Old Air a/c, 72 power disc brakes w/stainless lines, 3.42 gear,T-56 6-speed, original paint(what's left of it). Dakota Digital Dash
jlmtrout is offline   Reply With Quote
