Old 08-06-2005, 01:55 PM   #1
red86chevy
Lowering question
I was thinking of lowering my 86 sb by adding a flip kit to the rear and 2.5" drop springs in the front. How hard of a job is this? I want to be able to do it myself. what is involved in a flip kit? It just puts the springs on the bottom of the rear end instead of the top correct? And to do the springs do you just remove your old ones and put in the new ones or do you have to replace other parts also? Is this the best way? I'm really looking for a 2/4 drop. I think this will give me about what I want. Sorry but I'm new to lowering.
Thank you
Jeremy
86 c-10 383 w/ sportsman II heads comp 286h cam Edlbrock RPM Performer intake Holley 750 th350 w/2400 stall 3.73 gears with powertrax No-Slip posi unit. Just broken in good. Will get a 1/4 time this week.
red86chevy is offline   Reply With Quote
Old 08-08-2005, 05:06 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
If you are mechanically inclined, then it should be not problem doing this yourself. Carefull with the front springs as they will be under pressure when you remove the spindle. I use a jack under the control arm to keep the spring from launching.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 08-08-2005, 05:12 PM   #3
cochino12
It followed me home?
cochino12's Avatar
I am a bit of a caution freak so I always wrap a chain around the spring just in case also. Not to bad of a job just take your time and good luck
adam
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 08-08-2005, 05:18 PM   #4
bigarmzz
bigarmzz's Avatar
you'll end up regretin not doin a 5/7
trust me on this one
1987 350 TBI lowered 5/7
bigarmzz is offline   Reply With Quote
