One of the few GMC'ers
check engine light? HELP!!!
i recently put a new 350 into my 87. now ever since then when the tranny kicks down to passing gear the check engine light comes on and it seems to have a lot less power and the gas mileage goes way the heck down. does any one have any ideas on this.
87' ![]() "Young, Dumb And Full Of Cum" |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Put a jumper (each end of a jim clip) in slot A and B of the ALDL and turn the key on and count the flashes. It will flash 12 like this: flash......flash, flash 3 times then show a code. Find that code and look it up here: http://www.troublecodes.net/GM/86-88_578.shtml or here: http://www.techedge.com.au/vehicle/aldl160/vn_aldl.htm
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
STILL PLAYS WITH TRUX
It sounds like you up set the tranny tv cable adjustment after your engine change go here to see how to check and adjust it.
I assume you still have the 700r4 installed in the truck. http://www.tciauto.com/instructions/...ble_adjust.htm |
it bring up the code that says its not getting the data from the distributer to the computer.
Thats your EST Eletronic Spark Timing bypass this is a one wire connector with a tan and black stripe wire find that and reconnect it and that should cure the problem.
The EST should be somewhere close to the dist. near the back of the firewall. Also befor you reconnect it get your timing light out and make shure your base timing is set at what is specified on the under hood lable. As long as this wire is disconnected the SES light will remain illuninated. Last edited by 87 STEPPER; 08-11-2005 at 03:26 PM. |
wire is conected and light isnt always on
No No
If memory serves me theres a ground wire attached the the ESC harness. Thats about the only way that item wouldent function unless you damaged the harness durring the engine swap. Doesnt make sence it would come on whne the truck downshifts. Usualy when somthing like that happens in a situation is a vacuum related sensor. What number code did you pull?
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
