![]() Join Date: Feb 2004
Master Cylinder
Will a 67 master cylinder fit on a 66? I am asking about will it bolt up to the firewall and 66 rod work ok to the brake pedal? I know I will have to run a proportioning splitter block for the brake lines and redo the brake lines.
Also will 71-72 spindles fit on a 66? I can solve the outer tie rod problem. I will be using the ball joints made for the spindle year. thanks |
