08-06-2005, 09:33 PM | #1 |
Radiator Support Clip
What are the clips called that go onto the radiator hold downs and where can you get them?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
08-06-2005, 09:55 PM | #2 |
not sure what and were you are talking about. give more description please.
08-06-2005, 10:12 PM | #3 |
This is a clip that goes onto the end of the radiator hold down brackets that bolt down to the rad support of the truck.
08-06-2005, 10:25 PM | #4 |
After doing some digging it looks like its called a j-nut. I called hardware stores around my area and they dont have any. Does anyone know where I can find these?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 Last edited by skokie; 08-06-2005 at 10:25 PM. |
08-06-2005, 10:28 PM | #5 |
NAPA had some I'm sure any reputable auto store will have them
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
08-07-2005, 06:17 AM | #6 |
You mean the J-nuts that the bolt/screw holding the fan shroud to the radiator brackets screw into?
Those are available thru 67-72 vendors (as are the hex head bolts/screws), but you might source them at a hardware store since they are just regular J-nuts. Just take the shrould holding bolt/screw with you.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
08-07-2005, 11:53 AM | #7 |
i have heard them called a body clip or sheet metal fastener. napa does sell these. most napas have to order them. they are a comon piece used in many areas in the older cars and trucks. now they are plastic of a differant style.
08-07-2005, 11:59 AM | #8 |
I have a bunch of those (good used) w/ bolt if you need some. Give a PM if you want some. Latter cheesewagon.
'91 suburban 350 TBI - R 700 4 new daily driver '72 Cheyenne Super 49,000miles 350/350 frame up resto w/ matching numbers. |
08-07-2005, 02:52 PM | #9 |
Watch out for your cornhole !
...also called tinnerman nuts.
08-08-2005, 03:04 AM | #10 |
67-72 Addict!
I have bought them at Home Depot and Lowes in the hardware section. They are in the wide pull out drawers.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
