Old 08-07-2005, 02:33 AM   #1
hotrodhomi
hotrodhomi's Avatar
got 20s?
What offset are you running with your 20” rims? I have a 5/7 drop right now. I just got my truck back from paint and the 15” aluminums have got to go. I'm looking at running a 35 series tire.
hotrodhomi is offline   Reply With Quote
Old 08-07-2005, 11:20 AM   #2
bodydropped
umm 20 on a 5/7 u better make sure before u drop the cash that u can turn wihtou out hitten the frt fender lip i had a 20 on my truck witha 5/7 and wasnt able to turn
bodydropped is offline   Reply With Quote
Old 08-07-2005, 07:07 PM   #3
hotrodhomi
hotrodhomi's Avatar
Anyone else have this problem? Do I need to bag it first?
Old 08-07-2005, 10:22 PM   #4
bodydropped
well u can but u can go i think 2 or 3 in the frt and be clear but u can always run a weird offset but then u got to worry abotu when u turnin and start to rub on stuff on the inside of the rims
Old 08-08-2005, 01:07 PM   #5
static22
Anybody runnin 20's on a 5/7 drop. If so details please!
static22 is offline   Reply With Quote
Old 08-08-2005, 03:20 PM   #6
Turbo85GMC
Turbo85GMC's Avatar
Can you turn lock-to-lock with a 5/7 drop right now with your stock 15" rims?
Anyone running the '95(ish) Impala SS 17" rims with a 5/7 drop?
'85 GMC 1500
"Friends don't let friends drive stock!"
Turbo85GMC is offline   Reply With Quote
Old 08-08-2005, 03:55 PM   #7
static22
I can currently turn lock-to-lock with my 15x8's. I may not be a full 5" low in front. It could be just 4" or a little over.
Old 08-08-2005, 04:01 PM   #8
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
I was when mine was running.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 08-08-2005, 10:25 PM   #9
hotrodhomi
hotrodhomi's Avatar
I don't have a problem with what I have now. 245/60/15. No rubbing. But with 20s, the overall height will increase. I'm worried it will rub.
Old 08-09-2005, 01:35 AM   #10
AspecialZ
Street Rod Restoration
AspecialZ's Avatar
rubbing
your best bet then is to go with a 18"/20" combo 5" backspacing 9.5 " in the rear and 8" 4.5 Backspacing in the front, as long as you stay with 50 series or smaller (ie. 45 40's) you should be fine, but you can not make a full tilt turn, especially at high speed, it will drag on the fender well. I would make sure the suspension is tuned correctly. 5-7 with 20"s all the way around is impossible unless air bagged...
Follow me on Instagram @ hot_rod_shop
AspecialZ is offline   Reply With Quote
Old 08-09-2005, 01:59 AM   #11
hotrodhomi
hotrodhomi's Avatar
do you have this combo? Do you have pics?
