Old 08-07-2005, 12:17 PM   #1
crosby
crosby's Avatar
what size bolts for tranny to engine block?
I have an 87 K20 (which happens to have an early 70's frame and axles), and I'm sticking in a fuel injected 350, mating to a TH400. I don't have the bolts that go through the bellhousing into the block, and want to be sure they're not too long (or too short). Anybody know how long they are supposed to be? It's not 100% where it needs to be, so I plan on using the bolts to finish lining everything up. The guide pins are almost in place, but there's about 1/4 to 1/2 inch of space between the block and the bellhousing right now. I still have to bolt up the torque converter and flexplate too, anybody know what size and length bolts I need for that? Should I use split lockwashers on the flexplate/torque converter? Thanks very much for any help you guys can provide!
Crosby
1978 Chevrolet K10 stepside
NH
crosby is offline   Reply With Quote
Old 08-07-2005, 12:33 PM   #2
86 GMG
i believe 2 1/2 should work but put a smaller diameter bolt through trans and in to the block hole see how deep it goes and go from there
torque bolts no washer just raw balls and torque and thread lock
square body trucks an addiction or an investment either way they consume all my extra time and money
86 GMG is offline   Reply With Quote
Old 08-07-2005, 01:11 PM   #3
crosby
crosby's Avatar
That's a good idea, thank you.. off to the hardware store
Crosby
NH
Old 08-07-2005, 08:51 PM   #4
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
It wouldnt hurt to use washers. I would if it was mine.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 08-07-2005, 09:03 PM   #5
plumbcut
california fill
I agree w/ mylilbowtie.... I use lock washers on my bellhousing bolts.. keeps from scarring up the aluminum trans, too...
plumbcut is offline   Reply With Quote
Old 08-07-2005, 09:39 PM   #6
bigblock73
yeller
bigblock73's Avatar
I just bought new bolts for my setup, and IIRC, I purchased 1 1/2 or 1 3/4" bolts. I believe they are also 3/8" threads too. Don't take this as gosphel, I have a bad memory...but I am pretty sure about the length.
bigblock73 is offline   Reply With Quote
