Old 06-26-2002, 08:37 PM   #1
Chevy Punk
Inner door bottoms
Has anyone replaced their inner door bottoms? How hard was it? I will need to replace mine soon and was wondering if anyone had any pointers.
Chevy Punk is offline   Reply With Quote
Old 06-26-2002, 09:08 PM   #2
Randy70C-10
Randy70C-10's Avatar
Here's a door that I did. Only use as much of the patch as needed to fix the rusty area. Take your time, measure many times to ensure that your cuts are accurate, and weld in short beads. Don't over-heat the metal, or you will warp it!!
Randy70C-10 is offline   Reply With Quote
Old 06-26-2002, 09:33 PM   #3
Chevy Punk
What about were the outer door skin overlaps the inner door?
Old 06-26-2002, 09:55 PM   #4
Randy70C-10
I welded it solid. It wasn't the correct way to do it, but it turned out almost perfect. One thing I forgot to mention, tack weld the bottom on, then install the door and MAKE SURE IT STILL CLOSES!!! Then, finish your welding.
Old 06-26-2002, 10:17 PM   #5
bigvinnie
bigvinnie's Avatar
to have it come out looking factory, you'd have to drill out the spot welds along the bottom of the door and gently pry the overlapping strip back so you could get the old door bottom flange out and the new one in....
then once you got the new door bottom lined up, bend the overlap back in position (maybe with a hammer and dolly), clamp it gently with some vise grips, and then do some plug welds where the old spot welds were...
sounds like a pain in the arse don't it?
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
72 Stepside Project
bigvinnie is offline   Reply With Quote
