front suspension
I'm getting ready to take the front crossmember off an 85 and putting it on my 69. I can't find the post about how to do it. Anyone have it handy?
New Member
I know Geezer had posted about doing this with the front end out of a 1988 suburban. I tried to search for it , but the search feature is disabled. Basically you unbolt it from the donor vehicle and bolt it in your truck. I think that there were 4 holes that needed to be enlongated. He said that it was an easy swap. I will be trying the same swap in the next month or two and anticipate no problems.
-Doug- |
72 BB C30 Super LongHorn
![]() Join Date: Nov 2002
What is the advantage of this?
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS ![]() |
#4 | |
New Member
But you get that from the spindle disc setup from a correct disc brake assembly with out the crossmember
New Member
Well i can't speak for the other guy . I have no disc brake parts for my 67. What i do have is a 88 suburban with 300,000 miles on it. So i can have a front disc setup with a little work and little or no cash out of pocket.
OK, Now I see the direction you are going!!!!!! :-)
So I just jack it up, unbolt it, roll it out and put the new one in?
Weekend Warrior
Pretty much. You might have to drill a couple of holes (or don't who's looking).
If you don't want to do the whole crossmember you can do all the upper and lower control arms/steering stuff. I would suggest doing the whole crossmember though...much safer (don't have to deal with taking the springs out)
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered ![]() ![]() ![]() |
I'll probably try and take the old one out tonight then. I'll go see if I can take some pictures real quick.
Designated A-hole!
Take some pics and write up a FAQ thread on it for us.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
this won't mess up allignment or ride height will it? i'm considering a 77 c10 to 72 c10 swap.
