Old 08-07-2005, 07:01 PM   #1
dave666693
dave666693's Avatar
distributor question
I have a 68 with a 327 and the original distributor and mechanical points. Can anyone recommend a replacement distributor with electronic ignition that a rookie could easily install? Not looking for high performance at this point. Thanks
dave666693 is offline   Reply With Quote
Old 08-07-2005, 07:19 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
A stock junk yard HEI is pretty hard to beat. If you look around a bit, you'll find one with a new module, coil, cap and rotor. PPl will try to tune up a car to get it running and then tow it to the junk yard once they run out of cash and give up. I bought at least a dozen like so in the last few years. Heck, I got a junk yard HEI for my caddy 500 with an accell super coil on top, and a brand new set of accell wires to...all this for 20 buck.
You just can't go wrong there.
Simple to wire, it's almost as easy as a simple remove and install. Look on the FAQ page, there are a couple write ups on this.
Old 08-07-2005, 08:14 PM   #3
Jwill41
Jwill41's Avatar
I just put one in the 283 in the 67. It sure made a difference. Of course it would since the mechanical advance mechanism was rusted together and would not advance. I gave $30 for dist, cap, and a pretty decent set of wires.
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
Old 08-07-2005, 08:36 PM   #4
dave666693
dave666693's Avatar
looked at the FAQ's on HEI and got a ton of info. Thanks. I'm off to the junk yard!
Old 08-07-2005, 09:56 PM   #5
rage'nrat638
rage'nrat638's Avatar
item number 2 on parts board
http://67-72chevytrucks.com/vboard/s...04#post1358604
rage'nrat638 is offline   Reply With Quote
