Having issues
what is this stuff worth?
I have a '72 that still has all of the orig. smog equipment intact. Soon the motor will be coming out, and replaced with a vortec 5.3. Somebody mentioned that there actually might be some interest in the smog parts??
Quando Omni Flunkus Moritati. The Man's Prayer: "I'm a man, but I can change, if I have to, I guess." |
Having issues
its all about the +6 inches
Well, not ALL the smog stuff is there, the carb isn't smog legal, and I'm not sure about the coil, plus I see no heat riser and the air filter is gone....I'll assume it's removed for photo reasons though.
All messing around aside, personally, I'd put it all on e-bay, one smog item at a time. If you lived in Cali long enough, you probably know what a PITA it was to pass smog a few years ago, and many states are still making old stuff pass. |
He's installing a 5.3, so as far as smog laws go, his truck will become a 2000-something.
![]() Join Date: Apr 2005
I don't need smog parts but I'm interested in your oil dipstick and tube! It looks like the bracket is broken.
Todd
1978 Dodge Omni |
Having issues
in cali. the way the law is written, I can still get smogged for any reason (tho I am smog exempt.) They cannot do a visual inspection of the motor, BUT they can do a visual inspection for gas leaks. I do have the orig. air cleaner with a new K&N air filter, Reman'd points distributor, and a qjet from a 396 ss i could slap on if the situation called for it. (smog guys cannot tell difference :p) The dipstick tube is not broken, but it is "bent" or not installed correctly afik. I would have to check that again.
I've been asking for weeks for a pics and a measurement of the power brake booster re-enforcement bracket.... the one that mounts to the lower firewall. I'm tring to fab one up for my truck and I can see a little of yours. Can you help me out?
Hey I remember that engine. How was your trip home? While at Blues you mentioned not having help to install the axels and I wanted to offer labor when possible. Let me know ahead of time and I will try and arrange the time.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. |
#9 | |
Having issues
The trip home was uneventfull. I think I will be needing a new tcase tho, I am gettin an awfull beginnings of some bad sounds as you get on and let off the gas. The rear seal officially is bad too ![]() :americanrider: I will take a pic or two, and some measurements. ![]()
Quando Omni Flunkus Moritati. The Man's Prayer: "I'm a man, but I can change, if I have to, I guess." Last edited by masterbeavis; 08-08-2005 at 02:28 AM. |
