08-07-2005, 08:37 PM | #1 |
New Member
5 lug axles for 67 chevy
I will be putting a front crossmember setup from a 88 suburban under my 67 SWB 1/2 ton (6 bolt). I would like to have 5 bolt rear axles with the same bolt pattern. Is there any axles that will swap right in? If not is there a rear end with 5 bolt lugs that is a dirrect replacement? I have tried to read through all the posts ,but there are so many. Any help would be greatly appreciated.
-Doug- |
08-07-2005, 09:20 PM | #2 |
its all about the +6 inches
Asuming you have a coil rear, the only direct swap would be a 71 or 72 rear end.
08-07-2005, 10:27 PM | #3 |
New Member
Thanks very much..
08-08-2005, 06:39 AM | #4 |
You can have your axle and drums redrilled at Moser for 100 plus shipping. You could also have a set made for 250 I think?
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
08-08-2005, 10:05 AM | #5 |
Yup, new Moser axles , with studs & shipping were $260 to my door
http://community.webshots.com/user/hotrodhorn |
08-08-2005, 05:54 PM | #6 |
New Member
Thanks for the Moser idea. That will probably be the way i go.
Thanks Again, Doug |
