Old 08-07-2005, 09:22 PM   #1
tomatocity
tomatocity's Avatar
Help ID this Holley
I have decided to use the Holley that came with the truck. I have attached some pics so I can get help IDing (model number) the carb. I was hoping to add a spring bracket that mounts from the carb. Thanks in advance.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 08-07-2005, 09:45 PM   #2
rage'nrat638
rage'nrat638's Avatar
600 holley carb....
vacuum secondarys....
manual choke......
good carb.....won't pass emmissions with it ....if you have to test,,,,,,
rage'nrat638 is offline   Reply With Quote
Old 08-08-2005, 02:01 AM   #3
Chevyboy1962
C10 now is a GMC
Chevyboy1962's Avatar
I'm running the same carb, it's a 600CFM. The only difference on mine is that it has electric choke, but otherwise it's identical. I picked up a rebuild kit for mine at the local hyperformance shop here in town.
David
*1962 C10 swb fleetside, big window, custom cab 350/TH350 combo...Hot Rod
*1963 C10 lwb fleetside, small window 230/4 speed...Blvd Cruiser
*1931 Ford 5 window coupe (soon to be Hot Rod)... Father & Son project
Chevyboy1962 is offline   Reply With Quote
Old 08-08-2005, 09:32 AM   #4
3 on the tree
Those numbers stamped on the front of the air horn should give you all the info. Write em down and show em to the parts guy for the correct rebuild kit.
3 on the tree is offline   Reply With Quote
Old 08-08-2005, 03:01 PM   #5
tomatocity
tomatocity's Avatar
Thanks for the information. I updated my post. Do you know the Holley model number?
Old 08-08-2005, 04:14 PM   #6
TN70C10
the model # is the # on the air horn.
TN70C10 is offline   Reply With Quote
Old 08-08-2005, 09:28 PM   #7
tomatocity
tomatocity's Avatar
It is a 1850 and I found the part number for an electric choke. Thanks everyone.
Old 08-08-2005, 09:35 PM   #8
masterbeavis
Having issues
masterbeavis's Avatar
The "type" of carb is a 4160. I have about 8 of these turkeys laying around in my garage, if you are ever in my neighborhood, I could give you one you could use for parts to convert to an electric choke. As far as the spring bracket is concerned, kragen carries a package of them that has an assortment of them. I say just loop the spring into one of the various holes and call it good. Why spend $8 on 10 studs you will not use?? :P
Quando Omni Flunkus Moritati.
The Man's Prayer: "I'm a man, but I can change, if I have to, I guess."
masterbeavis is offline   Reply With Quote
