Old 08-08-2005, 09:23 AM   #1
fade94
fade94's Avatar
Can you test the oil gauge?
My oil gauge is pegging on the high end. At idle, it is right in the middle. Is there a way to check it? I don't want to put after market gauges in the truck. If it's bad, I want to replace it.
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates)
67 short step project (will get SWB from the 68)
67 Camaro, #'s matching (my wife's)
03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear
fade94 is offline   Reply With Quote
Old 08-08-2005, 10:21 AM   #2
jhow66
jhow66's Avatar
New engine? Sounds ok to me. Full right is 60 PSI-30 in middle. Old engine (402) went a little past center-new engine (502) goes full right. I have another gauge and it reads 60 PSI when old gauge is full right.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 08-08-2005, 10:50 AM   #3
fade94
fade94's Avatar
Engine has 8-11000 miles on rebuild. Has Hi-perf oil pump. Just trying to make sure everything is working.
Old 08-08-2005, 11:35 AM   #4
byrd
Union Electrician
byrd's Avatar
you need an 80 lb oil preesure gauge, and that would solve the pegging problem
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 08-08-2005, 11:40 AM   #5
fade94
fade94's Avatar
As long as it's stock looking...
I want the inside of the truck to be either all stock, or all Autometer.... Stock is much cheaper...
Old 08-08-2005, 12:06 PM   #6
boraxman
Keepin an eye out
boraxman's Avatar
Mine pegs also as probably most out there, I would only worry if it goes to zero while its still running
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 08-08-2005, 12:10 PM   #7
fade94
fade94's Avatar
No doubt...
I have 3 Autometer Phantom gauges, oil, temp and volt...but would need speedo and tach to complete the set and they are NOT cheap...
I have speedwarning dash in my 71 that I may sell and set myself up with autometers.
Old 08-08-2005, 10:13 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
You can get an 80psi guage from a c/40 and up truck, looks exactly like the one in your rig right now.
however, I see no point in all reality. If it pegs the guage, then you have plentyu of pressure.
It's when it goes the other way that you need to worry.
