08-08-2005, 09:24 PM | #1 |
Vacuum Advance Solenoid needed 1972 Chevy
Hi All!!
I need some help or info on the "Vacuum Advance SOLENOID" What is the part # at local stores? here are the pics: http://www.mvpc.com/truckvac1.JPG http://www.mvpc.com/truckvac2.JPG Jeff Smith Pensacola, FL 850-475-5030 mvpco@yahoo.com THANKS!!! |
08-08-2005, 10:01 PM | #2 |
its all about the +6 inches
Throw that sucker away. I have personally never seen one. That is a poorly thought out emissions control item that is pretty much worthless.
08-08-2005, 10:06 PM | #3 |
Premium Level Member
I just installed on on my 77 k5 this weekend after I failed smog. That was the only thing I needed for a visual inspection. Cost me $15 at NAPA auto.
They have several colors(temps) and it only affects idle at start until temp hits the designated temp. Easy install and no performance issues (383) Edit: I just looked at your pics...looks a bit different than mine, but same name. The one I got(I did not have one prior) screws into Intake manifold and opens up vacuum to the distributor once the engine temp hits 180 or whatever its set at.
69 K5 CST stock- 350, 4speed 77 K5 - 383, auto, 6" lift, D60 front, 14b rear, 39" tsl's, Last edited by jakeslim; 08-08-2005 at 10:10 PM. |
