08-09-2005, 09:04 AM | #1 |
Removing wiper arms...What's your method?
Ok. Someone out there must know a way or a tool that will remove these things without damaging the cowl. PLEASE SHARE...
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates) 67 short step project (will get SWB from the 68) 67 Camaro, #'s matching (my wife's) 03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear |
08-09-2005, 09:13 AM | #2 |
20' Daredevil (Ret)
I have one like this http://www.etoolcart.com/browseprodu...l-KDT2039.HTML, it has padding on the underside to protect the cowl.
08-09-2005, 10:50 AM | #3 |
I use a small crowbar wrapped in a towel. Dont forget to push in the tab before you pull!
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
08-09-2005, 11:28 AM | #4 |
I was having this same problem earlier and go a response but I don't think I followed all that well. So I brought pictures this time. First, which way does the little clip underneath the arm go? See picture below:
And here is an aerial view of what I am talking about: Now, I know the pics aren't great but I was hoping they would help anyone willing to help understand what I was trying to do. Second, once you get the clip adjusted do you have to keep holding onto it in that direction while pulling the arm off or just pull the arm off? Thanks to any help in advance. P.S. Stocker, is the tool just the best way to go? I'd rather not spend $20 after shipping for a tool I will only use a couple of times.
72 Chevy Short Bed Fleet: 350/TH350 - Sold - Now trying to sell the parts that I have left over. _______________________ 2006 VW GTI |
08-09-2005, 11:29 AM | #5 |
I USE THE K-D WIPER REMOVAL TOOL ALSO. IT SAFELY REMOVES WIPER ARMS IN 2 SECONDS WITHOUT THE USE OF TOWELLS,RAGS,CLAW HAMMERS, PRYBARS, WD-40, PLIERS, CHANNEL LOCKS OR PIPE WRENCHES. JOHN (& THEY ARE LESS THAN $10 AT MY LOCAL NAPA)
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST Last edited by junkyardjohn; 08-09-2005 at 11:32 AM. |
08-09-2005, 11:47 AM | #6 |
there ya go
08-09-2005, 12:37 PM | #7 |
Thanks Matt, I was trying to pry that little thing down. Obviously which much more success cussing than getting it off.
08-09-2005, 02:14 PM | #8 |
no problem, good luck later, they can be tight. maybe spray some rust eater, penetrating fluid on the shaft.
08-09-2005, 06:56 PM | #9 | |
20' Daredevil (Ret)
08-09-2005, 08:01 PM | #10 |
I drilled a small hole below the pivot hole and just under where the arm is when raised. I now just raise the arm, drop a nail/paperclip/whatever through the hole and it holds the arm up. Now you can easily work the little tab that holds the thing on the shaft.
Andy,Phx AZ '67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...) "23 C-Cab-sold '48 Ford 8N tractor(still working) '67 Scout(Now on the road) '70 MG B.-sold |
08-09-2005, 10:49 PM | #11 |
20' Daredevil (Ret)
Walker - genius!
08-10-2005, 12:39 AM | #12 |
Half a bubble off!
Got a pic of that Walker?
Just call me LB. '71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads. |
