Old 08-09-2005, 01:29 PM   #1
woody96
woody96's Avatar
Question Changing out PS belt
Anybody got some good scoop as to how to change out and adjust a PS belt? Do I need to take off all the other belts first? How do I loosen the PS belt and adjust tension? Oh, BTW, it's a 1984 C10 with 305......
"Fighting for our freedoms....."
woody96 is offline   Reply With Quote
Old 08-09-2005, 01:35 PM   #2
bigblock73
yeller
bigblock73's Avatar
Yes, you need to remove at least the water pump belt since it sits in front of the PS belt. All you need to do is loosen the PS pump bolts that bolt thru the PS brackets and pivot the pump enough to allow the belt to slide off/on.
bigblock73 is offline   Reply With Quote
Old 08-09-2005, 01:45 PM   #3
woody96
woody96's Avatar
How many bolts am I looking for? I see one, that looks like when loosened, allows the pump to slide some--tighten and loosen----there are more bolts?
Old 08-09-2005, 09:30 PM   #4
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Yeah there are three one the water pump, one in the driver side cylinder head and one around the exhaust manifold area in the front depending if you have a/c. But it will still be in the same area just not on the exhaust manifold. Most have some type of bracket to help support the ps pump.
I use a small adjustable wrench to tighten the belt back up on the ps pump.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 08-10-2005, 08:31 AM   #5
woody96
woody96's Avatar
Exclamation
So, I have 3 bolts to loosen and tighten back up to do the PS pump belt? Is that what you are saying??
Old 08-11-2005, 05:10 PM   #6
MylilBowTie
Right turn Clyde
Uhhh yeah, 3 bolts need to be loose to move it for adjustment. I think there are two that loosen and will then be able to move but if the third bolt is tight it isn't going to move much if any. It is more fun trying to tighten the belt back up with one hand and tighten all the bolts back up with the other. But it can be done.
Old 08-11-2005, 05:13 PM   #7
woody96
woody96's Avatar
Thanks.......Uhh, sorry, I am pretty much a Barney Rubble with this stuff.....
Old 08-11-2005, 05:14 PM   #8
MylilBowTie
Right turn Clyde
Forgot to add to there are two bolts to loosen the alternator to get that belt of also. One at the bottom going into the cylinder head and the other is on the top alternator bracket.
If you need I can send you pictures how to do it. I will need your email address though. Let me know
Old 08-11-2005, 05:26 PM   #9
woody96
woody96's Avatar
Don't worry about the pix, --------I sure appreciate it!!!
