Old 08-09-2005, 02:22 PM   #1
newin72
HEI connectors
somebody on here posted a while back a link to a place where you could by the connecters for the HEI. for the tach, and power.
anybody know where that was?
newin72 is offline   Reply With Quote
Old 08-09-2005, 04:27 PM   #2
TireSmoke420
One of the few GMC'ers
TireSmoke420's Avatar
i just use a spade wire terminal thingy works great
87' Silverado 4x4
"Young, Dumb And Full Of Cum"
TireSmoke420 is offline   Reply With Quote
Old 08-09-2005, 05:01 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Summit has them.
Old 08-09-2005, 05:12 PM   #4
shifty
Questionable
shifty's Avatar
I did what Tiresmoke said. It worked with a little finagling (think I had to take my bench grinder to the male spade to shave a mm or two off the sides).
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 08-09-2005, 05:28 PM   #5
jtminton
II Timothy 4:2
jtminton's Avatar
I just used plain ol spade connectors. Didn't need any modification, either.
72 C-20 2WD LWB Custom Camper Deluxe 350 4 Speed "Project Lazarus"
MY TRUE PRIDE AND JOY
"Dangit, Bobby, people will see that oil stain and think I'm a drunk."
jtminton is offline   Reply With Quote
Old 08-09-2005, 06:11 PM   #6
Jwill41
Jwill41's Avatar
spade connectors here. perfect fit.
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
Old 08-09-2005, 06:12 PM   #7
mtdave2
newly minted old timer
mtdave2's Avatar
well, i used to use the spade connections too.. heavy on the used tp. it will work fine, but if you a like me, and have muphy on your ass all the time. you run a chance of shorting the tach wire with the batt wire...=blown up module or coil..(see my request for new hei on parts boad..lol)
ill be buying the correct connecter..
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
Old 08-09-2005, 06:44 PM   #8
Jwill41
Jwill41's Avatar
mtdave2 is probably correct. I am not running a tach so have not considered this to be a problem.
Old 08-09-2005, 06:55 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Junk yard!
Find an HEI equipped car with a pontiac engine...or a caddy. The dist is up at the front of the engine, which gives you a loooong wire. Chop it off, clean it up with some carb cleaner, and hook it up.
Nice original look too.
Old 08-09-2005, 07:58 PM   #10
pjmoreland
pjmoreland's Avatar
Go to www.summitracing.com and enter SUM-G5210 in the search box. It only has an 8" lead on it though.
pjmoreland is offline   Reply With Quote
Old 08-09-2005, 08:24 PM   #11
53burb
53burb's Avatar
Ecklers has the connections you want. They have the power and tach connections. Sorry I can't provide a link right now. Punch in HEI in the search on their website and you will see them.
53burb is offline   Reply With Quote
Old 08-09-2005, 09:06 PM   #12
72MARIO
72MARIO's Avatar
I got mine from GM. they were like 12 dollars for the 2 of them.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 08-10-2005, 12:05 AM   #13
lamar
lamar's Avatar
Got the factory style connector ends at napa, used a plug from an old harness, just added new wire.
72 C-10
lamar is offline   Reply With Quote
