Old 08-09-2005, 09:59 PM   #1
dmurphy68
How Hard?
I have a a 78 k5 balzer I6 with 4 sped tranny with granny gear. I also have a 95 fullsize chevy truck V8 350 2wd. My Question is how hard would it be to put the motor in my blazer. I know I would need the whole comp and harness so it would work. Will my tranny bolt, will the engine bolt etc... need some more input because i know i forgetting something
later
Darren
dmurphy68 is offline   Reply With Quote
Old 08-09-2005, 11:33 PM   #2
82c10
needin' money
easy, if you carb it
SWB Stands for Short Wide Bed
82c10 is offline   Reply With Quote
Old 08-11-2005, 06:52 AM   #3
dmurphy68
I want the injection for more reliabitly(spell). I need to find out what kind of tranny I have so I can see if it will bolt to my new engine.
Old 08-11-2005, 12:56 PM   #4
kevinr1970
If the newer engine is coupled with an automatic you might have to do something about pilot bearing or bushing I think. Maybe thats not the right part but when I was swapping an engine from a manual truck to an automatic truck the guy I was talking to thought I was going the other way and he had a concern there?
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 08-11-2005, 08:14 PM   #5
a28doc
'87 V20 4x4
a28doc's Avatar
youll also have to use a electric fuel pump and also make a return fuel line from the injection setup back to the tank and make sure you get a good aurflow setup Id use the one off the 95 and put it in the blazer. It may take you a bit to get it all done but youll have a sweet performing blazer when done good luck Doc
'86 K5 Blazer 4x4 FOR SALE
'87 v20 4X4
'99 S10 Blazer 4X4
a28doc is offline   Reply With Quote
