08-09-2005, 10:37 PM | #1 |
serpentine setup FAQ
is there a serpentine setup FAQ?
08-10-2005, 08:30 AM | #2 |
Designated A-hole!
Not that I know of.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
08-10-2005, 08:50 AM | #3 |
Keepin an eye out
There is little info on the whole internet on this conversion. I have most of my parts together. Im still looking for a reverse rotation fan and fan clutch. I have no idea when im going to get to it.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 Last edited by boraxman; 08-10-2005 at 08:53 AM. |
08-10-2005, 08:51 AM | #4 |
Keep On Truckin'
I installed a '92 Camaro serpentine setup on my truck. What do you need to know?
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
08-10-2005, 08:58 AM | #5 |
More Cowbell....
Got one on my truck as well. Not much to explain, except make sure you get a reverse rotation water pump.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
08-10-2005, 10:35 AM | #6 |
Keepin an eye out
One thing I would like to know is, the missing bolt hole on the passenger side head. Do you really need to drill and tap? I hear you can get away without it
Also I found this old thread: http://67-72chevytrucks.com/vboard/s....php3?t=132141
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 Last edited by boraxman; 08-10-2005 at 10:46 AM. |
08-10-2005, 10:59 AM | #7 |
New
If I have a short pump on my truck and the kit comes with a long, should I modify my fan shroud or just take it off completely and not worry about it?
What do you think of this setup? http://www.gmpartsdirect.com/results...umber=12497698 |
08-10-2005, 11:39 AM | #8 | |
Keepin an eye out
http://cgi.ebay.com/ebaymotors/ws/eB...category=38656
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
08-10-2005, 11:47 AM | #9 | |
Lovin' Life in Miss.!
08-10-2005, 12:06 PM | #10 |
More Cowbell....
I am missing that hole also and run the crap out of mine. Also running electric fans.
08-10-2005, 02:45 PM | #11 |
According to some GM gurus you can safely get by without drilling the P\S head just run the braces to be on the safe side.
I got my fan and clutch off of a 9C1 Caprice. Also with my setup a stock fan shroud will not work, I am using a BB shroud.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
08-10-2005, 05:36 PM | #12 |
Keepin an eye out
I may go with electric fans. What are some options, I know its been discussed but near impossibe to find.
One option I just read suggests F*rd Taurus dual fans. Also how have you guys wired these up? Full time? Thermo controlled? Im very interested..Thanks. Would like to see some pics of installed serpentines(including brace areas) and electric cooling fans if anyone would take the time.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 Last edited by boraxman; 08-10-2005 at 05:38 PM. |
08-11-2005, 10:34 AM | #13 |
Crappy pick of the brace. You can see it mounted to the back of the tensioner and the intake manifold. If you look close you can see there was no nut on the manifold portion, just the stud is sticking up. Good pick of the fans though. That is a Flex-a-lite 395. Another member relocated the controller enlarged the by-pass hole and fabbed up a new flap. If I had it to do over I would do the same. More effiecient(sp?) that way for highway speeds. Drawback to these is the controller. If it fries you are hosed. It is everthing to the fans. Temp sender and relay is integrated. You can toss it and wire it up like any other fan but I like the features the contoller offers. It has 2 stage fan speeds, +or- a/c signal input, temp input, man. off/on, status indicator led's... in short it makes it easy for a slacker like me. Oh,It uses a temp bulb inserted into the radiator at the return.
08-12-2005, 07:22 AM | #14 |
Is that fan setup special for our vintage of trucks?
All my trucks are gone now. I'll gladly take a free one |
08-12-2005, 09:34 AM | #15 |
It is listed as fitting our trucks in flex-a-lite's aplication guide. I could not figure out how to use any of the brackets that came with it though. I made my own mounts and so has everyone else that I have saw usung this fan.
I like this fan but think all the junk-yard fans a lot of people are using is a smart idea. (Provided they will keep temps down) They are a lot cheaper! This one just looked cool, had the rated cfm's I knew would work and had some cool electronics features to make wiring easy. |
