06-27-2002, 10:35 AM | #1 |
Now the others dig........
Heater wires
Some one said something about a Blue Heater wire that connects to something. My fan kind of works, but not really, how do you get to the blower and the heater core??????Is it lots of work????let me know!!!!!!!!!
68 Chevy C10 Stepside Black Primer 78 GMC Longbed White 09 Chevy Silverado Shortbed Granite Blue LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala MEMBER OF THE DRUM BRAKE CLUB Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX Certified Music Educator I hope Mom is up there watching and being my Guardian Angel "I've got a fever.....and the only prescription.....IS MORE COW BELL" -The Legendary: Bruce Dickenson "F#$@ 'em up!!!!!!" -The Legendary: Rogelio Escobar TRUCKY LINKS http://67-72chevytrucks.com/vboard/s...d.php?t=457750 http://67-72chevytrucks.com/vboard/s...d.php?t=461184 http://67-72chevytrucks.com/vboard/s...d.php?t=472848 http://67-72chevytrucks.com/vboard/s...d.php?t=417541 http://67-72chevytrucks.com/vboard/s...d.php?t=477788 |
06-27-2002, 01:21 PM | #2 |
I mentioned the blue power wire. After looking at the wire schematic, it apears that mine has been rewired in the past. It should be 14Brown and wired to the back of the fuse block. http://www.geocities.com/chevroletc1070/wiringdias.html
To access the core and blower you need to remove the pass side hood hinge. Don't forget to mark the hinge for realignment. You can remove the fan from here. If you want to remove the core, you need to drop the inner fender to remove the plastic case. You may have some leaves or some other crap in the blower cloging it up. Hope I helped. Mario
Mario and Mandy Hughesville, MD 20637 69 C10 305/350 71 K5 Basket case 75 K10 Rescue **Parting out** 77 MG Midget **Parting out** 15 6.7L Cummins |
06-27-2002, 03:37 PM | #3 |
Back in the sticks
Your switch may not be wired right too. If you don't have the right wires to the switch, your blower will not go to high. Check them against the wiring diagram. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
