Old 08-10-2005, 07:44 AM   #1
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Question Rear End Problems
I was trying to determine what kind of rear end I have, so recently I picked up a new rear end cover, might as well kill two birds with one stone. While proceeding to put it on, I put the rear end of the truck on jack stands. While on jackstands, I spun the right rear wheel.....click.click.click, and the left tire isn't spinning. So I turn it towards the back, click.click.click.....and the left tire kind of spins backwards. I move to the left wheel....turn the wheel forwards....click.click.click....and the right tire spins forwards, as well as turning the wheel backwards.
Any ideas why?
Also, to give a little more information, when I turn corners, I hear clicking out of each turn. I've asked a lot of people and they say that it's probably a posi.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 08-10-2005, 07:55 AM   #2
68C15
blood type; Retumbo
68C15's Avatar
sounds like either a worn out ratchet style locker or a gov-lock grenade
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 08-10-2005, 08:41 PM   #3
roger0080
Is this a 1/2 or 3/4 ton?
Do you know that you have a posi or locker in it for sure?
If it is 3/4 ton you probably have a No-Spin locker in it.
They should make some noise when cornering.
If it is a 3/4 ton and you hear the clicking while it is jacked up as you describe, I would venture a guess to say that something is worn inside that allow the locker to unlock too easily. Both wheels should turn. Just my thoughts. Not an expert on the No-Spins.
72 Chev C-10 90% restored (former AZ truck) ...
71 Chev K-20 Cheyenne my vacation crusier...
72 Chev C-10 Now retired and striped after many faithful miles...
72 GMC 1500 Retired to the junk yard after bought new in '71...
roger0080 is offline   Reply With Quote
Old 08-10-2005, 09:11 PM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Was the truck in gear when you were spinning the tires?
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 08-11-2005, 07:48 AM   #5
72BlckButy
Tot Roddin'
72BlckButy's Avatar
No, it was in neutral, which now thinking about it, would have made a difference. It is a 1/2 ton, and in speaking with some buddies here locally, I think that I have locking diff. However, I'm still not 100% positive that that's what I have. Probably not the smartest thing to do, but after checking out the rear end on Tuesday, I took it out on the street and brake torqued it a little, and she left dual tire marks, so I'm still not sure what I'm running.
-Nate
Old 08-11-2005, 07:52 AM   #6
68C15
blood type; Retumbo
68C15's Avatar
pull the cover & post a pic or 2.
