Gas Tank options?
I know the Blazer and Burb tanks work for the pickup, but what about other years and makes? Can you run a tank from a '73-87? I'm not having much luck finding a 67-72 Blazer to get the tank from and I'm tight on funds. I do see a lot of '73+ trucks being parted out, I'm all for some minor modification if that's all it takes. Thanks,
jd |
I'm also interested...First gens are hard to come by in my area.
Mine has definitely seen better days... ![]()
It's better to wear out than rust out! |
I have a brand new tank kit for a Blazer that I will sell for $200 including shipping within the 48 states. It includes sender, straps, everything. I have decided to go new stainless instead of modifying this one for efi. You are saaving around $100.
Mike |
The Blazer King
Yeah, I bought mine brand new for $250 shipped.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest. |
I KNOW they can be had for $250, but I'm on tight funds trying to build the motor. I can get a '73 for $30, but don't want to spend $30 if I can't make it work.
The question is still: Are there other years that work for a 67-72? The truck only cost me $600 to start with, seems silly to spend $250 on a tank at that point. |
Doesnt the 73 and up blazers have the filler neck on the passenger side?
For every person with a spark of genius, There are a hundred with ignition trouble. ![]() |
Not a bad nut after all..
As 70short/step stated the '73-up Blazer filler neck is on the opposite (passenger) side. There are two versions of these tanks--a 25-ish gallon and a 31-ish gallon. I've heard rumors this swap requires X-member modification.
Forgot to mention in my original post that I have the original tank out of my '69 K5 as well I would sell. Straps are rusty, bolts are no good. Tank is not all beat up but has a couple dents in the bottom. They are not all that bad. I was told it has a leak but I have not pressure checked it. It was holding a little more than a half tank of gas when I pulled it. I would sell it for $75 shipped. I will post a pic if anyone is interested.
Mike Last edited by Musclerodz; 08-11-2005 at 01:08 AM. |
FUEL CELL GURU
http://67-72chevytrucks.com/vboard/s....php3?t=165877
Scroll down in the thread and you'll see one other solution. Later, Mark |
huh ???
I just pulled a 73-up tank out of 72Blazerman's blazer last night. The 73-up is not as tall as a 69-72 but it is a little longer. The 73-up tank will be too close to the rear end on a blazer or SWB pickup and might hit the rear...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
#11 | |
I think the world needs a drink... ![]() Help somebody...If you can....VanZant We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men. Tracy Byrd ![]() Member# 13924 '70 c10, 350/350 '68 c10 250/4spd '68 c10 no eng/trans fac ps/pb/ac/at (future father/sons project) '48 Chevy Loadmaster |
Yes I do and it is a steel tank kit. I have one guy in line but he may take the used tank instead.
Mike |
#13 |
Let me know. Although I still have to clear it with mama.
#14 | |
Mike |
#15 |
Junior Member
if the new tank is still available, would you let me know please?
thanks mike |
#16 | |
Mike
Mike Redpath |
#17 |
Junior Member
let me know if there is no takers, i will take it then.
thanks! |
#18 |
Tank is sold.
Mike
Mike Redpath |
