Old 08-10-2005, 02:46 PM   #1
woodyjim
305 carb woes
Hey guys,
I,ve been reading on this site for quite a while and you guys really put out some great info! This is my first post though so be gentle. I just bought an '84 Silverado with a 305, 4 bbl. The carb seems a little sluggish at times (cranking especially) and my mechanic tells he put a kit in it for the previous owner last fall. Any suggestions on a carb upgrade/replacement for this manifold? Thanks!
woodyjim is offline   Reply With Quote
Old 08-10-2005, 03:13 PM   #2
rockman20
"The dude abides"
rockman20's Avatar
What do you mean sluggish especially on cranking?
It takes a while for it to fire? When it is running does it not perform well? Have you checked the choke on the carb? Is this a Rochester?
You come for answers and just get more questions!
RockMan
1993 Chevy Silverado C3500 1 ton dually
1994 Honda Civic
1969 Oldsmobile Cutlass S
1953 IH Farmall Super M
New to the fleet:
1992 Subaru Loyal
rockman20 is offline   Reply With Quote
Old 08-10-2005, 03:43 PM   #3
woodyjim
Thanks Rockman,
It does pretty well once running but sometimes it's a bear to crank. I usually end up pumping the accellerator like crazy to get it to fire up. Not sure on the rochester part. I'll have to check. Pretty sure it's a spread bore.
Old 08-10-2005, 05:04 PM   #4
a28doc
'87 V20 4x4
a28doc's Avatar
my Blazer takes bout 6 pumps before starting its always been that way boutonce every few months I start it up and spray carb cleaner in it for several minutes also that seems to help keep it from gumming up and it seems to run better afterwards
Doc
'86 K5 Blazer 4x4 FOR SALE
'87 v20 4X4
'99 S10 Blazer 4X4
a28doc is offline   Reply With Quote
Old 08-10-2005, 09:54 PM   #5
ureckme
ureckmefixit2@cox.net
Fuel filter or fuel pump. Matt
That's U RECK ME FIX it 2
74 Chevy Short Bed
355ci Sportsman II 64cc Angle Plug
Crower Custom Grind .462in .486ex
Dyno Test 422hp @ 5600
And it's got a Holley
3.73 Gears
12 Bolt 3.73 w/Posi
700R4 Going In
I'm a Body Man So There!
That's why it's not painted
ureckme is offline   Reply With Quote
Old 08-11-2005, 12:30 AM   #6
79gmcc15
Gettin It One Pice At A Time
79gmcc15's Avatar
By the way WELCOME from washington state!
RIP ELJAY
Work In Progress 1979 GMC C1500 Trailering Special.
Getting the truck done, one piece at a time.
“You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan
“I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby
79gmcc15 is offline   Reply With Quote
Old 08-11-2005, 03:46 PM   #7
woodyjim
Thanks for the welcome guys,
This is a rochester Quadrajet spreadbore carb. Seems like I remember Carter coming out with a spreadbore replacement a while back. Is this worth checking into or should I just go with a whole different manifold/carb combo? I'd like power and economy if possible. Thanks, Jim
