08-10-2005, 07:26 PM | #1 |
Pics of GV O.D.
Looking from the rear towards the transfer case
08-10-2005, 07:27 PM | #2 |
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
08-10-2005, 07:29 PM | #3 |
Had to move these towards the rear.
08-10-2005, 07:30 PM | #4 |
I guess I don't really have the hang of this yet but I'm trying
08-10-2005, 07:32 PM | #5 |
Had to put a picture of my baby in here.
08-10-2005, 07:33 PM | #6 | |
The LuvShack Garage
08-10-2005, 07:36 PM | #7 |
Cheap like GOLD. I got it for $2700 and did the install myself. But to me it was worth it to get dual use out of the truck. But you are right. They aren't cheap!
08-10-2005, 07:38 PM | #8 |
User #12137
it looks good in there !!!!!!!!!
08-10-2005, 07:39 PM | #9 |
one of the parts trucks im looking at has a governer something of the option sticker , i just cant rember if its the truck that has a running 6cy or the one with no motor or tranny . this is a pakage deal i am working on.
is this what that governer option is, what does it do, how does it work , and whats it worth if its the same thing. thanks john i like the paint on that truck
2004 Silverado 2500HD Crewcab 4x4 2000 TOYOTA 4RUNNER 1971 CHEYENNE LWB (THE LOVE SHACK) 1967 c-10 lwb (THE FARMERS DAUGHTER) Last edited by jc; 08-10-2005 at 07:41 PM. |
08-10-2005, 07:52 PM | #10 |
its all about the +6 inches
jc, this is a gear vendors...not governer. This is a gear splitter that ives you fiest gear with high and low, second gear with high and low, and third gear with high and low gear...making a 3 speed a 6 speed.
What you have described is a rev limiter. |
08-10-2005, 08:04 PM | #11 |
thanks longhorn , i take it what im talking about is wortless
2004 Silverado 2500HD Crewcab 4x4 2000 TOYOTA 4RUNNER 1971 CHEYENNE LWB (THE LOVE SHACK) 1967 c-10 lwb (THE FARMERS DAUGHTER) |
08-10-2005, 08:12 PM | #12 |
Saving 1 truck at a time!
jc, If you miss a shift and insist on holding the throttle WFO or it gets stuck WFO your governor is PRICELESS!
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
08-10-2005, 08:19 PM | #13 |
very cool. how did you hook it up? did it need some on-the-dash control? Or is it all done on the carb/gas pedal?
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
08-10-2005, 08:26 PM | #14 |
That sure looks like ALOT of stress on the transfer case output housing to hold that whole thing up in the air like that. Try holding 2 lbs out at arms length allday. How much does the unit weigh? I'm sure it's neat-o though!
72 Chev C-10 90% restored (former AZ truck) ... 71 Chev K-20 Cheyenne my vacation crusier... 72 Chev C-10 Now retired and striped after many faithful miles... 72 GMC 1500 Retired to the junk yard after bought new in '71... |
08-10-2005, 09:07 PM | #15 |
I would guess its about 50 pounds. The NP205 transfer case is really thick cast and it should hold up ok. When I pulled the case I had to use a floor jack, man that thing is built!
08-10-2005, 09:22 PM | #16 |
The unit has a control switch that hangs under the dash to put it on automatic or manual control. It also indicates when its in od or normal. It has an electronic control box mounted inside the cab on the firewall that all the wires go to and it makes the decision to shift or not shift. Also there is a floorboard switch like our headlight dimmer switch that you can push and shift in and out of od when you are in manual mode. It uses a signal generator hooked in with the speedometer to give the brain speed information needed for making the decision to shift on automatic. Everything is color coded and the control box connections are keyed so you can't hardly hook it up wrong. Its really no biggie to do, I just had other stuff to adapt the th400.
08-11-2005, 10:43 AM | #17 |
Oh, man. I want one! Hmmm, I wonder if they ever get pulled off of totaled trucks....
08-11-2005, 11:04 AM | #18 |
Very cool.
What if you were in 1st gear and in 4 wheel drive going up a slick hill...then accidently kicked the floor button into OD ??? Would there be a BOOM?
1970 Blazer CST Looking for NOS items for my CST restoration. |
08-11-2005, 12:50 PM | #19 |
Weellllll, There is a provision for a lockout when you are in 4wd. I haven't installed a switch to activate it cause I just turn it off. I put my foot switch up higher on the floorboard so there isn't much chance of hitting it.
08-11-2005, 01:20 PM | #20 |
Dash switch with status indicators. You can see the floor switch on the floor underneath it. Its safely up high out of the way. Last edited by gator2511; 08-11-2005 at 01:32 PM. |
08-11-2005, 01:24 PM | #21 |
This is the "Brains" of the unit. You can see the 4x4 lock out socket is empty. The little black rectangle is actually a digital readout that tells you different things like how many times od has been engaged etc. Last edited by gator2511; 08-11-2005 at 01:28 PM. |
08-11-2005, 05:57 PM | #22 |
huh?
I'm jealous! I'd love to have a gear vendors unit, but they're darn expensive. I think I'll probably end up going with a 5 or 6 speed manual, that's the only way I'll truly be happy anyway.
Not to hijack the thread, but I think the Gov-something jc is looking at on the option sticker could possibly be a Gov-Lok Posi unit. Maybe not, but I do know there is such a thing is a gov-lok.
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
