08-11-2005, 09:39 AM | #1 |
left side sag
New kid here. Here's a shot of my baby, an '86 Silverado. Mostly stock. What's the cheapest easiest way to level the suspension to take out the 1"-1 1/2" sag in the left rear corner? Also what's the recomended way. I don't care to lift it, just level it. thanks.
08-11-2005, 09:52 AM | #2 |
67 is sold
It may be the fuel tank causing that?
08-11-2005, 01:17 PM | #3 |
It has a 40 gal tank mounted on center so that wouldn't be it. I've looked arround undernieth for an obvious answer with no luck.
08-11-2005, 01:22 PM | #4 |
needin' money
i am usually on the truck board, it maybe is bodymoubts, that is why my cab does that, or yours maybe could be worn leaf springs
SWB Stands for Short Wide Bed |
08-11-2005, 05:45 PM | #5 |
www.73-87chevytrucks.com
If it isn't the body mounts, then that is just how the spring ended up settling.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
08-11-2005, 09:32 PM | #6 |
sounds like the springs are worn out.i would just buy 4 new stock height springs. most suspension companys carry them, exactly for your situation. I know that s10's always have a slight driver side sag in them, but i think it is the gas tank with them cause its mounted on the outside of the frame on the driver side.
sam.
-American Pride- 71 2wd k5 Blazer-under major construction Anyone know of a 71 4x4 k5 in Nor Cal???? let me know- lv2whl@hotmail.com |
08-11-2005, 10:06 PM | #7 |
MY EX DRIVES A BROOM
ive have that same prob on one of my trucks.....the smallest leaf in the spring pack is cracked
They say nobody's perfect. I'm a nobody, so I must be perfect. Building Nemo -1968 C10 Long Bed FRED -1947 KB-2 International |
