Majician
1972 2wd to 4wd questions and pic request
I have a 1972 C10 that I would like to convert to 4 wheel drive.
What I have from a 73-87 truck - 6" all spring lift, D44 completely rebuilt, 14 Bolt FF with disk brakes, axles are geared 4.56, rear spring hangers, 38.5" Ground Hawgs, and a divorced 205 from a Dodge. I want to use all this stuff on my '72. My truck has a coil spring rear now and I need to convert it to leaf springs. I have two sets of 73-87 rear spring front mounts (pictured below) that I wanted to bolt to the frame using one set as a homebrew shackle flip, but it looks like the frame tapers in from the coil springs to the cab. It looks like the rear spring front mounts wouldn't be straight. Are the 67-72 rear spring front mounts different than the 73-87 mounts? Anyone have any pics of the rear leaf spring mounts? Anyone have any pics of the front leaf spring shackle? If you've made it this far, thanks for reading. ![]() |
![]() Join Date: Feb 2001
You need to do a lot of measuring of frames and comparing. Not sure of the differences. Seems like it would just be easier to me to just use the newer frame if it is availble.
Majician
The newer frame ('79) was bent real bad and the body was rusty, so I scrapped it. I have this '72 that sits around and does nothing, so I thought about converting it.
Junk/Daily Driver Club
![]() Join Date: Feb 2004
On your 2wd frame where the parking brake cable goes thru it will need to be cut out and plated smooth. Also the rear spring front perches are different 2wd and 4wd. I`m working on a shortbed one now it was a 72 GMC leaf spring frame. Good luck!
![]() Later Willis
Daily Driver: 1970 C-20 400 sbc,sm-465,Dana 61 one ton SRW rear, 3.07 gears, locker. ![]() There are three kinds of people: those who make things happen, those who watch things happen, and those who have no idea what happened! Last edited by 67-72williso; 08-21-2005 at 10:25 PM. |
Professional Grade
If you hadn't flexed that poor 79 so bad, she'd probally have been ok
![]() Can't really give a whole lot of advice on how to install it, but I am definitely looking forward to seeing that 72 riding tall like your 79 did, that truck was awesome, regardless of how rusty it was ![]()
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
#6 | |
Majician
#7 | |
Majician
![]() *If* I convert my C10, I'll be sure to post some pics of the progress. I have a trick or two for it also... if they will work. |
