Majician
TBI fuel pump location and plumbing?
I am swapping an '89 TBI motor into my '72 C10 and wonder what fuel pump did you use, where you mounted it, and what did you use for the fuel lines to the throttle body? I still have my tank behind the seat and it has 3 different size lines that come through the floor.
I have a TBI wiring harness and custom chip picked out for $360. The harness only needs 3 wires (power, ground, and ignition) and the chip has some "performance upgrades" and will make the computer work fine without the VSS since I plan to use my TH350 transmission. I am open to suggestions if anyone knows of a better deal on a harness and chip. |
![]() Join Date: Aug 2004
I've looked into TBI for my 454, I found some possible fuel pump options from affordable-fuel-injection.com. Where did you price the harness and chip?? That sounds like an ok deal....
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
#3 | |
Majician
I have a 95 Motor in mine, but I am going carburated. But as you know there is no place for a mechinical pump. I mounted mine on the frame right beside where the fuel first meets the frame.
2006 Titan SE Crew Cab Daily Driver 2005 Mazda Tribute (Wifes car) 1969 C10 SWB 350/3 Fleet "Max" 1969 Chevelle 2 door 350/3 |
![]() Join Date: Jan 2001
I am running a TBI with my Megasquirted 402. I used a frame mounted Ford van/truck external pump and accumulator w/filter and switchover valve. It works just dandy. No need for an in tank pump. Just a return line. Use the sender unit from a '72 w/auto trans sender unit (has fuel vapor line) or put a return line in your existing one.
Good luck! |
use a stock tank from a 86-91 suburban or blazer mounted under the bed. it has the pump in it i think. remove your in cab tank, and replace with 2 12" subs and shave the the gas filler. just my two cents.
Majician
Thanks for the info. I will check out "frame mounted Ford van/truck external pump and accumulator w/filter and switchover valve" before making my final decision.
"use a stock tank from a 86-91 suburban or blazer mounted under the bed. it has the pump in it i think. remove your in cab tank, and replace with 2 12" subs and shave the the gas filler. just my two cents." I thought about this and it may still be an option if I can find a tank in good condition and cheap enough. The truck is just going to be an old trail beater, so no subs are needed. Last edited by 1972; 08-13-2005 at 05:41 AM. |
