![]() Join Date: Feb 2001
V8 power steering for sale
Power steering set up complete with pump, brackets for small V8, hoses, and steering sector. $200 shipped.
JQ |
Do you know the condition. Leaks, slop in the box anything I should know? Is the steering sector the same thing as a rag joint?
It was removed from a non-running truck, but I have no reason to suspect that it is bad. The sector feels tight and the pump still had oil in it. I have pulled several of these off parked trucks and they work fine. The rag joint is actually a coupling between the column and the gearbox. This gearbox (sector) still has the rag joint on it.
JQ |
OK, how about $175 shipped???
Joshua |
computer illiterate
whats the truck in your avatar? did you get another 4x4?
72 2wd blazer 72 swb 4x4 |
![]() Join Date: Jul 2004
What year is that from ? Is it 2WD half ton ?
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
Meathead : That's the same 4X4 I had when you came down - still haven't got the lift kit on it!! I figured it was time to change my avitar since I sold the other truck over a year ago!!!
Green Machine : It came off a 69 or 70 model 2wd with 350 V8. Joshua |
Would you have a crank pulley for that ?
computer illiterate
what did you have it painted? i thought it was multiple colors? maybe im thinking of someone elses truck
JQ-72: Do you still have the power steering set up? Can you tell me what crank pulley was used with this set up? I also would like to know what groove was used on the crank pulley.
Is the power steering set still for sale?
'67 2wd LWB Fleetside '71 4wd LWB Fleetside |
#12 | |
#13 |
Still for sale. $150 shipped (continental US). If it doesn't sell at this price, I'll just keep it!!
I do not have a crank pulley for it.
#14 |
I'll take it for $150.00 shipped. Let me know how you want to be paid. I can send you a money order or whatever you like.
#15 |
2500HD - PM sent!
Joshua |
#16 |
paypal and return PM sent. I hope you can find the mounting hardware. If not I'm sure I can figure it out.
#17 |
JQ-72 did you get the paypal?
| Bookmarks |
