Old 08-11-2005, 09:31 PM   #1
Free88
Free88's Avatar
Speedo
Please help. Have a 91 chevy 1500, speedo doesn't work does anyone on this forum have any ideas. Posted on 88-98 forum but no replies. Thanks.
1986 Silverado Short box fleet side. project
2005 VW Tiguan 4 Motion
1997 Blazer S10 4x4
1990 Chevy Silverado K1500 Extended long box
Free88 is offline   Reply With Quote
Old 08-11-2005, 11:11 PM   #2
Russell
Professional Grade
Russell's Avatar
Check to make sure that your speedo is getting power, and also check to make sure that there is something of a signal coming from your DRAC (the little yellow box somewhere nearby your ECM, it converts the 40 pulse per driveshaft revolution signal coming from your tranny into the 4 pulse per speedometer cable revolution signal that your speedometer wants)
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 08-11-2005, 11:45 PM   #3
Free88
Free88's Avatar
Thanks. WIll give it a try.
1997 Blazer S10 4x4
Old 08-12-2005, 02:40 AM   #4
Russell
Professional Grade
Russell's Avatar
Yep, no problem!
Should be fairly easy to figure out! Those trucks speedometers only need power ground, and a VSS signal to operate
Old 08-12-2005, 08:28 PM   #5
piecesparts
Parts and more parts
piecesparts's Avatar
The early 90s vehicles had some problems with the pickup unit in the tranny failing. Once it goes the speedo will not receive information for a speed.
piecesparts is offline   Reply With Quote
Old 08-12-2005, 08:45 PM   #6
Russell
Professional Grade
Russell's Avatar
Your check engine light would also come on in that situation. If you do find out that your tranny sensor is the problem, gimme a PM, and I can send you a known good one from my 89's old blown 700r4 for the cost of shipping There is always the possiblity that your check engine light may be burnt out or something.
Old 08-12-2005, 09:15 PM   #7
piecesparts
Check engine light ----Not always---Had one go and the light didn't come on. My light was good also. If it is made by man, it might never work right.
