Old 08-12-2005, 12:36 AM   #1
newin72
filth flarin flipping @#%%^ bolts!
trying to get the last bracket off the old motor so I can finish up sandblasting and painting.
thats right the one last bolt..
this is on the rear most part of the AC bracket that mounts to the exhaust manifold.
wrench slipped right off, socket stripped it further. (yep soaked everything for several days...
oh well the head is already round so might as well go after the vise grips...
now it is more round..
I tried hammering on a smaller 6 point socket... good thing craftsman has a lifetime warranty!
pipe wrench, nope...
broke three sawzall blades
new freshly sharpened titanium bit in high speed air drill barely puts a dent!!!
any suggestions?!?!?
newin72 is offline   Reply With Quote
Old 08-12-2005, 01:02 AM   #2
screamin_c102
screamin_c102's Avatar
socket weld a nut to the head of the bolt
You may also want to strke the bolt on the head (like a nail), this will dislodge some of the corrosion that has it stuck.
screamin_c102 is offline   Reply With Quote
Old 08-12-2005, 01:10 AM   #3
newin72
I don't have a welder, but I think I know where I can borrow one... what do you mean "socket" weld?
Old 08-12-2005, 02:32 AM   #4
AusMarty
You can weld another bolt to the head of the bolt you are trying to remove, or if you have plenty of room around it you can weld a peice of steel to the head at 90 degrees to it to give you something to lever on, that bit of heat freom the welding helps to loosen it as well, Good luck
AusMarty is offline   Reply With Quote
Old 08-12-2005, 08:25 AM   #5
Tynee
I miss this truck.
Tynee's Avatar
Blue tip wrench? Once you get the manifold (if I'm thinking of the right bolt) off, you'll have more of the bolt to work with.
'07 GMC Acadia SLT. Sweet ride.
'08 Crew Cab Z-71 short bed. Really like this truck A LOT.
Tynee is offline   Reply With Quote
Old 08-12-2005, 08:35 AM   #6
68cajun
68 C/10
68cajun's Avatar
gring the head off with a grinder and them remove the bolt once you have the manifold/ Bracket off.
(2009) GMC Sierra Denali 6.2 AWD
(67 C/10 fleetside SWB)
(2018GMC Yukon Denali) Wifes Car
68cajun is offline   Reply With Quote
Old 08-12-2005, 01:31 PM   #7
lowrider79
dynomite
lowrider79 is offline   Reply With Quote
